V6 Xantia......... the beginning of another adventure
x 5674
Re: V6 Xantia......... the beginning of another adventure
Trainman wrote:
KP wrote:My money's on a vacuum leak Steve.
Yeah, mine too, it's just that I'm going to the Heysham Classic Car and Bike show tomorrow, may have to see if I can have a look...... subject to weather...
My cousin lives in Heysham, must be five years or more since I have seen her, must find an excuse to go over there sometime soon.
x 8422
superloopy wrote:Jimimah ...
Wasn't she a puddle duck?
xantia_v6 wrote:A good fix is to find a few cm of more flexible hose and splice it in with a 3mm joiner.
That's what I did on my first V6 Mike. Still good after a few years now...
Trainman
(Donor 2018)
x 43
Unread post by Trainman »
CitroJim wrote: Wasn't she a puddled?
Is what I think you mean......:)
Steve
http://c6owners.org/index.php
Trainman
(Donor 2018)
x 43
An early start this morning to head down to Jim's. Items on the agenda today are, first and foremost, the gearbox, if there's time I would also like have a look at the spheres as the suspension can go hard at times and the cruise, plus anything else we can think of, as we go along....
Steve
x 8422
I'm here all primed for a spannering session Steve :wink: :-D
Mandrake
x 695
Unread post by Mandrake »
Get your scope ready too Jim ;)
Although it could be the crank sensor there's a good chance it could be a wiring loom fault, and I don't fancy tracking that one down...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 8422
Mandrake wrote: Although it could be the crank sensor there's a good chance it could be a wiring loom fault, and I don't fancy tracking that one down...
I've thought of that Simon :evil: I'm really trying not to and hoping it's not!
Also, Chris570 came up with the thought that the LPG system most likely uses the same signal too so it could even be related to that. Some of the pikey wiring I've seen around LPG installs certainly makes it worth checking.
Mandrake
x 695
Oh, I completely forgot about the LPG conversion. That's definitely a suspect too. Is there any circuit diagram with that or is that too much to hope for ?
I doubt it piggybacks on the engine speed signal between engine and gearbox ECU's though as I believe that's a digital waveform that would be highly specific to the model of car and ECU's, if it needs an RPM signal it most likely gets that directly from the crank sensor which is more like a rounded off triangle wave. But even there it could be causing a problem if there is chafing in the wiring to the LPG kit causing a momentary short...
Good thinking, I'd be giving that LPG kit wiring a good going over...
Simon
1978 CX 2400
Trainman
(Donor 2018)
x 43
Well I've arrived at CitroJim Central, just awaiting the Grand Master to polish his tools :-D
Steve
x 3296
OO ERR Missus!
KP
x 27
Unread post by KP »
Good luck guys! Hopefully the LPG setup isn't the cause!!
x 3296
KP wrote:Good luck guys! Hopefully the LPG setup isn't the cause!!
If it is, I hope it is simple to track down and resolve. Good luck. [-o< [-o< [-o<
x 8422
Thanks James and Will :)
It was not the LPG system but we did find the crank position sensor a bit iffy. We measured a good one at 380 ish ohms and the one on Steve's car started out at 700 ohms and kept rising toward an open circuit. Most odd.
Want a complete :twisted: to replace it though. Inlet manifold off, which meant disconnecting the LPG injectors, then we had to drain the coolant and disconnect four hoses before we could even barely see the sensor. Then it had to be got out. All in all a real good job and girly hands were very valuable! It all went well, we fitted a replacement and checked/cleaned the Bitron sensor and the over-temperature warning sensor. In fact the Bitron sensor was removed to give just a tad more access to the crank sensor.
Once again my little 1/4" socket set with a wobbly joint was essential...
As the MOT is due we rounded off the day by giving it a pre-MOT and greasing the height correctors. The front one was just a tad lazy but the grease seems to have sorted it.
All seems OK on test. Steve is now on his way home...
It's been a good day and fingers crossed the crank sensor was the problem [-o<
x 8422
Sadly the crank sensor wasn't the problem despite looking as if it was :( Steve has just called to tell me.
Somewhat gutted :( Still, at least we've ruled out one thing. We'll swap the ECU next and if it's not that then it must be wiring...
KP
x 27
Unread post by KP »
Book it into my local MOT place Steve and pop round for a brew and waffle as they like citroens :)
Good news on the sensor front and I'll keep everything crossed for this now being a closed issue!
