My cousin lives in Heysham, must be five years or more since I have seen her, must find an excuse to go over there sometime soon.Trainman wrote:Yeah, mine too, it's just that I'm going to the Heysham Classic Car and Bike show tomorrow, may have to see if I can have a look...... subject to weather...KP wrote:My money's on a vacuum leak Steve.
V6 Xantia......... the beginning of another adventure
- x 5671
Re: V6 Xantia......... the beginning of another adventure
- x 8389
Wasn't she a puddle duck?superloopy wrote:Jimimah ...
That's what I did on my first V6 Mike. Still good after a few years now...xantia_v6 wrote:A good fix is to find a few cm of more flexible hose and splice it in with a 3mm joiner.
Trainman
- (Donor 2018)
- x 43
Is what I think you mean......CitroJim wrote: Wasn't she a puddled?
Steve
http://c6owners.org/index.php
Trainman
- (Donor 2018)
- x 43
An early start this morning to head down to Jim's. Items on the agenda today are, first and foremost, the gearbox, if there's time I would also like have a look at the spheres as the suspension can go hard at times and the cruise, plus anything else we can think of, as we go along....
Steve
- x 8389
I'm here all primed for a spannering session Steve
- x 695
Get your scope ready too Jim
Although it could be the crank sensor there's a good chance it could be a wiring loom fault, and I don't fancy tracking that one down...
- x 8389
I've thought of that SimonMandrake wrote: Although it could be the crank sensor there's a good chance it could be a wiring loom fault, and I don't fancy tracking that one down...
Also, Chris570 came up with the thought that the LPG system most likely uses the same signal too so it could even be related to that. Some of the pikey wiring I've seen around LPG installs certainly makes it worth checking.
- x 695
Oh, I completely forgot about the LPG conversion. That's definitely a suspect too. Is there any circuit diagram with that or is that too much to hope for ?
I doubt it piggybacks on the engine speed signal between engine and gearbox ECU's though as I believe that's a digital waveform that would be highly specific to the model of car and ECU's, if it needs an RPM signal it most likely gets that directly from the crank sensor which is more like a rounded off triangle wave. But even there it could be causing a problem if there is chafing in the wiring to the LPG kit causing a momentary short...
Good thinking, I'd be giving that LPG kit wiring a good going over...
Trainman
- (Donor 2018)
- x 43
Well I've arrived at CitroJim Central, just awaiting the Grand Master to polish his tools
Steve
OnlineHell Razor5543
- x 3296
OO ERR Missus!
KP
- x 27
Good luck guys! Hopefully the LPG setup isn't the cause!!
- x 3296
If it is, I hope it is simple to track down and resolve. Good luck.KP wrote:Good luck guys! Hopefully the LPG setup isn't the cause!!
- x 8389
Thanks James and WillHell Razor5543 wrote:If it is, I hope it is simple to track down and resolve. Good luck.KP wrote:Good luck guys! Hopefully the LPG setup isn't the cause!!![]()
It was not the LPG system but we did find the crank position sensor a bit iffy. We measured a good one at 380 ish ohms and the one on Steve's car started out at 700 ohms and kept rising toward an open circuit. Most odd.
Want a complete
Once again my little 1/4" socket set with a wobbly joint was essential...
As the MOT is due we rounded off the day by giving it a pre-MOT and greasing the height correctors. The front one was just a tad lazy but the grease seems to have sorted it.
All seems OK on test. Steve is now on his way home...
It's been a good day and fingers crossed the crank sensor was the problem
- x 8389
Sadly the crank sensor wasn't the problem despite looking as if it was
Steve has just called to tell me.
Somewhat gutted
Still, at least we've ruled out one thing. We'll swap the ECU next and if it's not that then it must be wiring...
Somewhat gutted
KP
- x 27
Book it into my local MOT place Steve and pop round for a brew and waffle as they like citroens
Good news on the sensor front and I'll keep everything crossed for this now being a closed issue!
