Hydraulic Leak 2.0HDi Xantia - STUPID QUESTION
Rhothgar
(Donor 2026)
x 221
Re: Xantia 2.0 HDi Leak Identification
Unread post by Rhothgar »
Marc. Not sure you will have received any notification for the post above this
viewtopic.php?p=751264#p751264
as I just linked to your answer rather than quoting.
GiveMeABreak wrote: 27 Mar 2023, 16:31
Brake Piping
Return Piping
Brake Piping
Item 4 -
Item 5 - 488671
Item 6 - 488670
Item 7 -
Item 8 - 96106389
Item 9 -
Item 12 -
Item 13 -
Item 15 - 4 x 2 way union
I appreciate this is a big ask so please do whatever is necessary to make your life easier.
x 1998
Re: Hydraulic Leak 2.0HDi Xantia - STUPID QUESTION
Unread post by Stickyfinger »
Rhothgar
(Donor 2026)
x 221
Stickyfinger wrote: 07 Apr 2023, 07:22 Image
This may save you a lot of time
https://catalogs.ssg.asia/citroen/?lang ... 1GQ1QwMDAx
Thanks Alasdair.
Now I know exactly how much cunifer I need for the whole braking system. That’s that done in one fell swoop.
Interesting, or strange rather, how Items 5 and 6 are shown as 4.75mm diameter. Wonder if it’s a typo and should be 4.5mm?
x 1998
............yes I would think a typo.
Also worth checking that "coils" are measured in total amount of pipe or just length end to end across a coil
Rhothgar
(Donor 2026)
x 221
Stickyfinger wrote: 07 Apr 2023, 08:40
Coils are included in total length. That became self evident when I replaced Item 8 which is 2323mm. Coil itself adds 1000mm to the millimetre…
x 6956
So do you need my intervention or not now Roger or are you using that third party data link, please let me know as it's a fair bit to do otherwise?
x 1998
Pls NOTE: Roger, the 3rd party link can have errors as it is ---not--- an Up to date system........
Rhothgar
(Donor 2026)
x 221
GiveMeABreak wrote: 11 Apr 2023, 08:43 So do you need my intervention or not now Roger or are you using that third party data link, please let me know as it's a fair bit to do otherwise?
Ideally, yes please.
If you can have a cursory glance at the fiche SF provided about and if the official Citroen Fiche shows Items 5 and 6 at 4.75mm. diameter then I do not need that fiche it is matches the Official one.
However, if you look back at the last post on page 6 (along with the first post on Page 7), there are links to the other fiches you previously provided. It should become clear what I am doing.
Can you not simply screenshot the fiche info as Alasdair did in that one from the hooky site or does the breach copyright in some way?
And besides that link is for an HDi 90... :?
x 6956
I’m out at present, so will take a look when I get back
Rhothgar
(Donor 2026)
x 221
GiveMeABreak wrote: 11 Apr 2023, 10:10 I’m out at present, so will take a look when I get back
Marc. There is NO rush. This week is fine if you want to break it down.
x 1998
That site is not "hooky", by law they have to provide such info in those countries that host them.....BUT, as said, I do not think it is the most up-to date
Rhothgar
(Donor 2026)
x 221
Stickyfinger wrote: 11 Apr 2023, 11:04 That site is not "hooky", by law they have to provide such info in those countries that host them.
Meh! You know what I mean. You said yourself the information might not be correct... :-D
Now where's that kiss emoji!
x 6956
It isn't up to date as you say Alasdair and you'll find by that I mean at least 8-9 years.... the data is from an old Offline database and you'll see that is not officially sanctioned, probably not technically legal either. There are NO new vehicles from about 2013-14. So somebody has hashed together the data from the offline system.
I've seen this on a few sites, that have the identical out of date offline data an they will never provide anything newer than this as they would never be granted access to it by PSA. Everyone has to pay for the data from PSA, including the dealerships.
x 1998
Got to protect the big boys...........one reason "PSA" cars are not sold in the USA
Rhothgar
(Donor 2026)
x 221
Stickyfinger wrote: 11 Apr 2023, 12:04 Got to protect the big boys...........one reason "PSA" cars are not sold in the USA
Also, they don't want the reliability over the vast miles they have to drive using cheap fuel...
