x 8437
Re: Zel's Fleet Blog - BX, Jag XJ-S, Sinclair C5, Mercedes 208D & 230TE, AC Model 70.
Michel wrote: 27 Oct 2023, 01:03 "And people ask why I want to move"..
It's no different anywhere else. A couple of months ago I had a very minor off on the motorbike. Chap comes round the corner in his car, sees the bike on the floor and me standing around, and starts beeping and gesturing at me to get out the way! No checking if I was OK or needed help.
Agreed Mike...
I've been away for a few days and was very happy to return here... OK, I know I'm not actually in MK but close enough... You'll struggle to find anywhere significantly better, trust me... Go away for a week, tour the country and come back home. Then you'll realise ;)
Glad you've now resolved the P6 fuelling :D
x 3298
I have missed seeing Tesla and Star on your thread! I suspect they did that just to get some publicity!
x 2938
Michel
Unread post by Michel »
CitroJim wrote: 27 Oct 2023, 05:40
Yes, me too Zel. I love reading this blog, it's one of the best things on the Internet!
Zelandeth
x 1607
Unread post by Zelandeth »
You know I called that fuelling fault resolved? Yeah...about that.
First thing today I wound up swearing at the fuel pump again as I discovered that it had been leaking overnight from the base gasket.
Thankfully it stopped once I got in there with a stubby wrench and got a little more tension on it. Without having to remove it from the car yet again. A job I am thoroughly fed up of doing!
Very useful tools shorter spanners.
Would definitely have had to remove the pump otherwise.
With my confidence boosted by yesterday's good running we went out to drop off a whole bunch of oil at the recycling centre.
Aside from the temperature getting higher on the gauge than I would have liked before the stat opened (the joy of aftermarket parts?), things were going well.
Right up until about 90 seconds after that photo was taken.
That "fixed" fuel pump has only gone and completely stopped pumping.
Previously when it was playing up I was still getting *some* fuel, so you could nurse it along even when it was acting up. Today, nope. Nothing. My guess is that I'm going to find that one of the valves has unseated itself when I pull it apart. That however is purely going to be to satisfy my curiosity, it clearly just doesn't want to live so that pump will shortly be getting chucked in the scrap metal bin. Not without a certain degree of vindictive pleasure I might say given how much time I've wasted on it.
Electric pump and blank off plate have been ordered, along with a few other bits and pieces from my longer shopping list.
Thankfully Jim was able to bail me out, so salvation arrived in a Nissan Pixo and gave me a run back home (seriously, I was like five minutes drive away) to grab a couple of things to hopefully get me going again. Especially as recovery was estimating about two hours of a wait. Made it clear to the operator that we would be trying to get the car going in the meantime, and would call them up to cancel recovery if we were successful. I also asked for them to get the recovery agent to give us a call for an update before actually dispatching.
After we pushed the car out of the bus stop and into an adjacent car park to hopefully avoid me getting a parking ticket. Jim of course is sickeningly fit and didn't even look vaguely winded, it damned near killed me! We did however definitely prove that the brakes aren't binding as she rolls astonishingly easily once moving.
Grabbed all of the testing setup from a couple of days ago - which thankfully I hadn't reattached to TPA yet. One very quick and dirty get-me-home bodge was thrown together.
Power stolen from the starter solenoid supply (run pump to fill the carb bowls, disconnect, reconnect starter, start engine, disconnect starter, reconnect pump).
Ground sourced by loosening the coil mounting bracket bolt and squashing a wire under it.
The pump for all it looks precarious was actually pretty well wedged between the fuel lines themselves and the breather pipework so wasn't going anywhere - especially bearing in mind this was purely intended to last for the drive home which is all of five minutes. This is very much what you'd call a trail fix.
Horribly janky mess, especially using an unfused line from the starter solenoid, but it did get me home, the car not missing a beat the rest of the way.
Safely home.
The frustrating bit of failures like this is that this is how smoothly the car is running when actually getting fuel. Which I think is a good indication of the fact that I am actually making progress, even if it didn't necessarily feel like it this afternoon.
Shout out to Reeve's Recovery too. Contrary to the call handler's estimate, they called to say they were in the area and would be with me in less than 30 minutes - right about the point at which we got the car going. They were really polite though, even though they had basically just wasted their time because Autoaid hadn't passed on my message asking them to call us.
So, hopefully in a few days we will be back up and running - without that blasted fuel pump.
May use that opportunity to drop the radiator off to be recored, will see how time goes. Or I may tidy this setup a bit more. Main thing I need to do is to get an ignition switched wire into somewhere accessible in the engine bay. There is actually surprisingly little wiring in the P6 engine bay, and very few accessible connections. As I mentioned in a previous post I really need to get a non-ballasted supply to the coil as well, so I may well end up running two new (fused) feeds for this purpose from the fuse box.
An additional component I *will* be ordering will be an inertia switch to kill power to the pump in the event of an impact. Any vehicle using an electric fuel pump absolutely should have one fitted. It is a critical safety component - and like all of those systems they're things that you really hope never to test, but can prove very important if the worst happens.
Current fleet:
x 8437
It was great to see you yesterday Zel, even if it was not under the best of circumstances :)
That rainbow photo is spectacular and the P6 frames it beautifully :-D
One of you installing the 'get you home' pump for the album...
Here's hoping all will be good from now on. She's a lovely car and definitely worth all the teething troubles :D
c16rkc
x 104
Unread post by c16rkc »
Poor dog... :lol:
Perhaps he was jealous...
Can't beleive the behaviour you encountered on the roundabout, that's awful!
x 1083
Unread post by Rp0thejester »
Hold on a minute, Since when did you start driving a Nissan Pixo Jim!! Not impressed :shock:
x 3298
Since he swapped his Citroen C1 with his daughters' Nissan Pixo!
x 1083
So CitroJim is false advertising, it should be CitronissJim I'm shocked.....
x 1083
Great work on the Rover Zel, she looks amazing
x 3298
Don't forget he also has Bluebell!
Michel
Rp0thejester wrote: 28 Oct 2023, 20:36 Hold on a minute, Since when did you start driving a Nissan Pixo Jim!! Not impressed :shock:
About 9 years ago 🤣
x 8161
Rp0thejester wrote: 28 Oct 2023, 20:42 So CitroJim is false advertising, it should be CitronissJim I'm shocked.....
Not really Ryan, not when you own two Citroens, more model Citroens than Harrods and your own regular column in The Citroenian, not really false advertising at all!! :-D
x 1083
I know Mick, was only joking, like you driving Jap crap, just joking, Zel I would love to meet you and see how you work, you have alot of knowledge about engines and car systems that I would like to learn.
