So, the clone didn’t work.
I used HDD Raw Copy Tool v2.6 to clone the old SD image to a FAT formatted SD card.
All the partitions showed up in the new SD and I ran chkdsk on all of them to repair any corrupted files.
Installed the radio back in the car and now it’s stuck in boot loop.
The logo and the fan come on for a second, then switch off and the radio reboots again…
I guess I’ll need a fresh firmware installed.
Do you know where I can find v.2.77 or 2.80?
Thanks for your help
RT6 2.75.c.5 Firmware / Software Download
- x 1938
Re: RT6 2.75.c.5 Firmware / Software Download
Check your PM for links.
With a a bit of luck you might find that the configuration has cloned over.
It's possible that some of the components on you head unit's motherboard have failed but you won't know that until you get the SD card installed preoperly.
Pmm_P
Thanks Paul.
Yesterday I went for another try.
This time I copied the backup.img to the SD but cleaned the Windows System Volume Information from all the partitions before installing the SD back in the radio.
Once I switched on the ignition, the radio was working, was able to change radio stations and volume but the screen was stuck on the logo…
Today I’ll go for one last try with a new 32GB SD, if it doesn’t work, I’ll go for the full firmware installation.
Eliya0067
- New User
Can someone please send me the software? I have problems with the SD card on my RT6 radio.
- x 1938
What version are you looking for? I don't have 2.75 as I think it was only ever fitted at the factory. I do have 2.77 as next nearest though.Eliya0067 wrote: 03 Jun 2026, 19:21 Can someone please send me the software? I have problems with the SD card on my RT6 radio.
merlin135
Hi Paul,
I've been reading the thread, and I've got an already reported issue with my head unit reloading a phantom CD every 15 seconds along with a blank/black screen, and km instead of miles, that I cannot change at the moment of course.
I bought this 2014 RCZ phase 2 with this issue, so I have no idea what is the software version installed.
I'm happy to start with v.2.77 and upgrade up to the latest (v.2.86 I believe?) Once the system is functional again, but happy to take any thoughts and inputs you have of course as you clearly know A LOT about this system.
Many many thanks!
Alex
PS: I have installed a new 32GB microSD
card, formatted to the (standard?) FAT32.
Many many thanks!
Alex
- x 1938
Thank you for the compliment but I don't know as much as I would like to, believe me! I will PM you links to 2.77, 2.80, 2.85 and 2.86.
Check your PM in five minutes. Use at your own risk, etc.
FLOPI
Hi Paul,
I'm having the same problem with my RT6 unit, still on its original version (2.21), in my 2013 Citroën C4. I need version 2.31 or 2.77, which I can install via USB on the vehicule.
Can you help me?
Thank you
Can you help me?
Thank you
- x 1938
I will send you links for 2.31, 2.37, 2.71 and 2.77. Check your PM in 5 minutes.
Use at own risk. No liabiltiies, etc.
ketrap
- New User
Hi Paul,
for the past few days I’ve been trying to fix an SD card with a CRC error on my own; the CD drive isn't working either. Could you send me the software? I currently have version 2.75.
Could you also explain how to install it onto a new card using USB?
Fredo2b
Hello. My RT6 has a black screen with probably a corrupted micro sd card because there is a CD startup noise. So I can't know what the current software version is. My RCZ is from 2013 and the firmware has never been updated. Could someone help me and send me a link to versions 2.77 and earlier (USB) as I don't want to go straight to version 2.86, thanks.
- x 1938
@Fredo2b
Have you taken the RT6 out of the car? The firmware version fitted originally is quite often printed onto a label.
- x 1938
@ketrap
Apologies for not replying. Are you still in need of firmware?
Fredo2b
Hello. No, it is not indicated on the label. While doing some research, I found a photo I had taken of the screen a few months ago. And my version is RNEG 2.75.C.5. If you have this software version, can you send it to me? Thank you in advance.Paul-R wrote: 01 Sep 2026, 06:59 @Fredo2b
- x 1938
I don't think that 2.75 was ever released as a service upgrade and only fitted at the factory. The closest have is 2.77 and I'll send you a link for that. Check your PM in 5 minutes.
