Will's Citroen Xantia Activa
Sl4yer
Unread post by Sl4yer »
KP wrote:To be honest after flushing the system out it doesn't even go above 80degree's much anymore.
That's a little worrying... :? Is the thermostat the right one?
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I'd distrust the gauge accuracy, before distrusting the thermostat.
KP
x 27
Unread post by KP »
It gets to the upper edge of the thick white line for 80 if that makes any difference? Should it be an 82 degree stat thats in there??
x 8386
Hi Will :D
An emphatic YES. The Activa should and must have an 82 degree 'stat so yours looks absolutely correct. They run too hot with a standard 88 degree 'stat in there I've found.
Delighted the burst hose has caused no damage :D Told you they're tough old birds!!!
KP
x 27
Unread post by KP »
Im quite surprised really as the coupe was a turbo too and would have killed itself by now im sure of it if it had a hose pope and the old R5 GTT would definately have blown its HG into the dust :)
Hopefully tomorrow the strut top will be an easy job for them as well, ill also see if they can do a quick lexia on it as im sure the suspension ecu would need a reset as they are so sensitive ;) would be nice to see how well it performs when it can be pushed into corners a bit more and with teh fault codes cleared :)
