x 8125
Well I tackled the pipe issue only to discover the problem was a lot worse than it had seemed at first. The downpipe was full to the elbow just below the gutter so I had to break a low joint and drain it off first. Once empty I split the bottom joint and as I removed the support from below the whole pipe slid down and away from the gutter. As a result I had to remove the brackets and take the entire pipe down whereupon I realised that it was made up of no less than seven sections. Sadly four of the six 'pipe into cup' joins had been installed upside down allowing leakage at the joints and one of the remaining two joints was just a butt to butt taped up!! I decided it is time to renew the entire pipe so I have put the old pipes out to grass and I will get a man in to supply and correctly fit the new pipe. The gutter joint is too high for my single section ladder and I just can't be bothered to get the second section out of the garage, as it really is earning its keep as a very well stacked high level shelf now!! :?
So we shall call in our local man and have the job done including augering the soakaway to improve the draining. :-D
x 1939
Unread post by Paul-R »
Are you / have you power washing the wall to remove the green algae?
x 8125
Yes Paul I have done that and at some point when it has dried I'll give it a coat of the garden moss killer which I have used very effectively on the garden walls. :-D
x 8125
Another little job came on the radar when I swept up the first big downfall of leaves in the garden yesterday. I use the snow shovel to get them into the bin so I noticed it seemed a bit 'floppy' when I was using it:
The shovel
The shovel
Close examination revealed a crack:
A nasty crack
A nasty crack
Aha I thought a job for my newly acquired polystyrene cement:
Humbrol special for model making
Then I decided that my other recent acquisition may well be useful too:
The garage storage box
The contents
The contents
So I opened the crack to allow me to smear the cement along one side and then be held together by the bungee while I inserted the staples:
Prepared for applying the cement
Finally I clipped off the ends and the job's a goodun'!! :-D
x 1072
Unread post by Rp0thejester »
I used to be an avid model builder and I refuse to use humbrol poly cement, it's bliming useless imo. Plastic Weld is way better, dries super quick.
x 8125
That's interesting Ryan, I am the exact opposite, I prefer Humbrol cos I find it gives more time to adjust the joint before it starts setting!! :)
x 1072
If I needed to use any poly glue then I used Revell, wasn't as 'stringy' and dried in 15mins if not over used. But plastic Weld is the one for me as it melts the plastic into each other. But being in a shed maybe the fumes got to me :mrgreen:
x 8400
mickthemaverick wrote: 22 Oct 2024, 19:07
And there was I thinking that was for sticking broken parrots back together :? :wink: :lol:
x 2341
Unread post by MattBLancs »
CitroJim wrote: 23 Oct 2024, 05:44
Not a specific C3 Picasso adhesive then Jim? :-D
x 8125
I'm glad someone cottoned on to my reason for posting the cement!! :-D
x 8400
MattBLancs wrote: 23 Oct 2024, 08:23
Likely held together with the stuff Matt!!!
x 1996
Unread post by Stickyfinger »
Rp0thejester wrote: 22 Oct 2024, 21:49 If I needed to use any poly glue then I used Revell, wasn't as 'stringy' and dried in 15mins if not over used. But plastic Weld is the one for me as it melts the plastic into each other. But being in a shed maybe the fumes got to me :mrgreen:
And there lies its problem.....it can skin over deep joints and keep melting the plastic "internally", this gives the deep joints that then need filling to get a good finish....or worse still a big sink that will need a large correction (if you are a muppet.......I was with one kit :) ).
I tend to use the TAMIYA Extra Liquid Glue.
x 1072
I would never use plastic Weld on an wide gap, as a seam joiner it works perfectly, personally I use it to 'tack' the 2 parts together, if not correct then plastic Weld on the first tacks release it from each other. I like that adaptability. If everything is okay then use on the seam. I have found it really useful on things that have a huge gap by filling it with poly card, weld each side and file down. (Major off topic) I'm not a fan of Tamiya or Hasegawa, shake and bakes imo
x 8400
Rp0thejester wrote: 24 Oct 2024, 20:14 (Major off topic)
Nothing's off-topic in this forum Ryan ;) :-D
x 8125
I went into the garage last week during the afternoon 'ventilation hour' which is the hour that my fan heater and extractor fans run to maintain the dry roof from the condensation issue. Unfortunately I realised that the fan heater had fallen onto its back and was blowing cold air so I decided to investigate. After stripping it down I discovered the thermal fuse had blown, presumably as a result of the intake being blocked when it fell over, and thus prevented a nasty burning possibility.
I ordered a new fuse and this morning set about installing it. Obviously you cannot solder it into place as it is calibrated at 121ºC as you can see here on the old one if you zoom in:
MTMO  the blown fuse
MTMO the blown fuse
It did get me thinking as the original fuse had been riveted in place as shown here by the red arrows:
MTMO  the original fuse mounting point
I did not want to drill out and re rivet as the elements are very close and it would probably have ended in disaster!! :-D
So I settled for this work around and it is working fine!! (I also fitted a higher rated fuse as it was all that I could get but still well below 451ºF :-D )
MTMO   the new fuse crimped into position
Back in situ now with a strap to stop it happening again!! :-D
