RT6 firmware
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
x 1939
Re: RT6 firmware
Unread post by Paul-R »
When you replaced the SD card you will have removed the map and (if you use it) speedcam data. Maybe inputting this will unblock the situation. I will PM you a link for this as the next step to try.
The rest I am unsure of what to suggest. I do not know what data Mirascript downloads as its configuration backup. Maybe there's more in there than in the files you downloaded? Not much can be done now though. Another thought is that the internal hardware is starting to fail. Again not much you can personally do if that's the case but there are companies in Europe that can repair these units. I have already promised another member here that I will try to find the details of such places and will add you to the list.
Another thought. Maybe the USB socket and associated electronics is starting to fail and this is why you're getting the “MEDIA incomplete or damaged” message.
x 1939
Re: RT6 firmware
This post gives information about a company in Romania that repairs these units.
viewtopic.php?p=870835#p870835
EDIT
I have no personal recommendations but here are three results from a quick search of the internet.
https://www.lesevans.co.uk/
http://revivecaraudio.co.uk/read-more/
http://www.rwer.co.uk/services_carradiorepairs.htm
thanos31
New User
Re: RT6 firmware
Unread post by thanos31 »
Hello everyone,
I’m having a problem with a black screen on my 3008. How can I find out which version is installed?
x 1939
Re: RT6 firmware
The firmware version is sometimes written on the RT6 unit itself. Even if present, this presupposes that there haven't been any firmware updates since the car was sold.
Carneiro
New User
Re: RT6 firmware
Unread post by Carneiro »
Paul-R wrote: 31 Jan 2026, 11:30 According to the attached charts updating from 2.21 to any later version will mean losing your configuration settings. This will need either paying a dealer so that they can download the configuration files from the Stellantis servers or using Diagbox to change individual settings. You should be able to use Mirascripts to download the configuration file before you update and then apply it after updating. I strongly suggest that you do this.
Check your PM for a link in five minutes.
Hi Paul,
I have a 2011 Peugeot 508 with RT6, currently running RNEG2.1.G.5.
I'm having the same Bluetooth problem described by Brandon1998: Bluetooth works, but when streaming music it disconnects and I have to reconnect/pair the phone.
Following your advice in this thread, I've already used RT6 MiraScripts to back up User_com.dat and User_config.dat.
Could you please send me the link for the RT6 2.21 USB firmware?
Thank you very much.
x 1939
Re: RT6 firmware
Check your PM in 5 minutes.
Usual warnings. Use at own risk, etc.
