I am an Activaist-v6 and a 2.1Estateerr
Skull
(Donor 2026)
x 379
Re: I have become an Activa owner...Project Stictiva-V6
Unread post by Skull »
Just caught up with the thread Sticky
She looks really nice :mrgreen: well done on the effort put in 8-)
Gary
wurlycorner
x 271
Unread post by wurlycorner »
Excellent work Sticky, well done.
Hopefully mine will make it over this hurdle in the next few months, too...
Iain
CX DTR T2 Safari (silver)
x 2000
Unread post by Stickyfinger »
Spent the day with wires, soldering gun, heat shrink, split-tube and loom tape. I have cleaned and shielded WAY too may cable runs today....aggggggg, half the plastic split cable covers are just cracking into small pieces...crap stuff.
Used hardly any adhesive insulation tape at all today, and that which I did use I covered in loom tape....the new black adhesive loom tape I ordered recently is wonderful to wrap with and with its ends secured with heat-shrink and any breakouts taped and cable ties to secure made a result I an happy with.
New Fuel/Shock cut out switch fitted, the old one had been by-passed by cutting off the connector (thanks again Green Goblin for the replacement switch and connector) and joining them together....ummm, safe !
FYI.....The old switch rattled when shaken, the replacement did not.
No oil of water leaks after yesterdays change.
bxzx16v
x 35
Unread post by bxzx16v »
Sterling work on the activa Sticky.
Mark
x 2000
Cheers dude....
Pug bush has arrived, it is the same bush....
So....Activa ram bush is not NFP...........errrr..EDIT BELOW
x 2000
The Peugeot bush IS DIFFERENT.
Details of the two Bush's, why the NARROW outer Tube on the original Citroen Ram Bush ?
Total width is exactly the same
Note: the inner tube on the Citroen Bush has been pushed over to one side to show the inner "lip" of this item.
You can see how thin the rubber is here, ?? how this design would last more than a very short time is hard to know :)
x 2000
I will have a VERY Low mileage soon....for use from DayOne of car tax...(if the DVLA ever get their heads out of their backsides !")
BUGGER....its a cable speedo
For Sale...NEW CABLE Speedo....£15.00
DHallworth
x 167
Unread post by DHallworth »
The part number I have is 4059 11, Sticky. That's the one I gave you pictures of earlier. Need to look and see how they compare.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 2000
|Guess what I found....now, will he send it to the UK ?....I await the reply to this request.
I plan on using this as a MASTER for reproducing the pattern part which is NFP
Note: it has "Made in C.E.E.".=.Central and Eastern Europe, anyone know the factory ....poss in the Czech Republic ?
Edit
(anyone in France want to get it for me if he says no ?)
x 1454
Unread post by xantia_v6 »
You can have it sent to me if it helps. BTW I think CEE is the frenh version of EEC, not a reference to eastern Europe.
x 2000
Cheers....I will let you know what he says....I have PM'ed you the link to the vendor....it will be nice to have an original to copy from.
CEE.....agh.....and I thought it may be "standardised" EU speak.
DHallworth
x 167
Sticky, that part above (405911) is available directly from Citroen & Peugeot for £11.59 including VAT before you haggle any discount!
How much is the one you've found?
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 2000
Tried, parts department said NFP mate
(5 euro)
x 1454
The ad has been removed, I hope you got it. I have had a few failures trying to buy parts (and a car) from LBC recently.
x 2000
No email, no contact....so nope Fail
