XANTIA HDi RUNNING ROUGH
x 2341
Re: XANTIA HDi RUNNING ROUGH
Unread post by MattBLancs »
Skull wrote: 07 Feb 2026, 16:20 Cheers MattBLancs
I didn't think mine was too bad :?:
Agree, doesn't look terrible really.
There's a lovely video of my garden instead of what I wanted my wife to video :roll:
Ah, video!
I forgot, here's a live action version of the heat gun making a good EGR flame thrower:
:rofl2:
moizeau
x 429
Unread post by moizeau »
I've used this
https://www.ebay.co.uk/itm/305477691439 ... +black&itm for the Zeph11 and will use it ro replace an O ring on the GPz11 cylinder head
Pete
Rhothgar
(Donor 2026)
x 221
Unread post by Rhothgar »
SO many TWISTED Firestarters in this group!
I cannot wait to do mine. I might take to doing it out front with a bit of Keith blaring out just for good measure!
moizeau
x 429
Pete
x 5674
x 8110
I reckon this story needs a sequel!! :-D
https://www.thenorthernecho.co.uk/news/ ... ds-damage/
Huskyxantia
x 906
Unread post by Huskyxantia »
Brilliant stuff and 100% dedication with out a doubt, I cant wait to read its all up and running this has been an interesting follow
:-D
Skull
(Donor 2026)
x 379
Unread post by Skull »
Huskyxantia wrote: 07 Feb 2026, 20:16 Brilliant stuff and 100% dedication with out a doubt, I cant wait to read its all up and running this has been an interesting follow
Cheers, although it's taking me forever to get it back together .... 5 hours :shock: spent yesterday just getting the Intake Manifold on and torqued up, the main problem being access 8-[ having to wiggle the exhaust/turbo around and insert all my extension bars together though the 'transmission tunnel' ....all bar No. 3's lower nut torqued to 17 Ib/ft (might be able to check that one, once the exhaust is back in place).
I actually wonder (in hindsight obviously) if the cylinder head would have gone on with the Intake Manifold already fitted (guess I'll never know now :roll: )
An old repair on a LHM return pipe was also re-done as it was clearly holding on to not a lot of pipe...
Skull's - Dodgy LHM+ return
Repaired again (third time) but it's getting a bit too short now ... each time you trim a bit of frayed pipe you have to drill the end to widen the internal diameter to match the pipe or it wont go on.
I could really do with some extra length :oops: ..... or a new octopuss but it seems more secure now
Skull's - Still a bit dodgy LHM+ return
The next job is probably the Coolant Outlet
Then the Exhaust and Turbo back on (I think I'm still missing a couple of nuts that were dropped and haven't re-appeared yet ....)
Quick question if anyone knows ..... There doesn't appear to be an EGR to Intake Manifold gasket fitted or in the kit, will a bit of the gasket sealant do the job :?:
Whilst shoving the turbo around yesterday I got a look at the tiny impellor .... looks and feels in good condition ....but much smaller than I was expecting ...
Skull's - Tiny Turbo
Gary
Rhothgar
(Donor 2026)
x 221
Skull wrote: 20 Feb 2026, 11:43 I actually wonder (in hindsight obviously) if the cylinder head would have gone on with the Intake Manifold already fitted (guess I'll never know now :roll: )
Where's the harm in taking it off again for a bit of practice...
Brilliant! Keep going. Inspirational. I know it is no fun taking the inlet manifold off which is why I have had a gasket sitting in the boot for years waiting for me to take it off and clean it.
As far EGR to intake manifold gasket, that's a good question. I read it wrong initially and was going to say it's a metallised gasket but that is to the exhaust manifold. There are a couple of EGR configurations on the HDi DW10. I think mine is a push it almost with a concertina pipe?
Tiny turbos are gooooood! They spin in fast at low revs and don't lag. If you're up for a laugh add a large one too for the best of both worlds. The turbo on my Saab T16S is huge. 3-4" manifold from memory which is why it doesn't kick in until 3000 rpm but when it does, you don't want to be on the autobahn at 85mph in damp conditions as the wheels will spin...
x 8110
EGR to inlet manifold on my old C5 was an exhaust paste job. Worked for me!! :-D
Huskyxantia
x 906
That's a nice clean turbo no signs of impeller wobble either
:-D
x 8386
Looking very good Gary :D
Skull
(Donor 2026)
x 379
Exhaust manifold is back on and mostly torqued up (15 Ibf/ft) although No. 3 lower stud must have threaded slightly as the stud wouldn't fully tighten and although the nut has tightened up more than I thought it would, I haven't risked torquing it up fully.
Some of my struggle ....
This was over 3 days (about 15 hours fathing around tightening and undoing several times trying to get all the studs in correctly) eventually removing the offside engine mount to allow the last stud No.3 upper in the above video to be fitted, followed by the Coolant Outlet being fitted - photo shows bleed vent on top of thermostat housing (5mm Allen Key)
Skull's - Coolant Outlet re-fitted
One of the Exhaust nuts dropped on removal still hasn't been found (alternative fitted to No.4 lower stud) and my only worry is that it's fallen in the exhaust manifold ready to chew the turbo (worst case).
Additional delays trying to find the rubber breather pipe that joins the Camshaft Cover to the Intake Manifold .... the search continues .....
Also I can't find a torque setting for the Turbo oil supply banjo type fitting ....
Gary
x 2341
Skull wrote: 26 Feb 2026, 16:56 One of the Exhaust nuts dropped on removal still hasn't been found (alternative fitted to No.4 lower stud) and my only worry is that it's fallen in the exhaust manifold ready to chew the turbo (worst case).
Oh that worry would eat away at my mind!
Trying to think if removing the EGR valve would give means of introducing a borescope for a quick check?
Hang on will have a quick dig
x 2341
Found it, Peugeot 406 Haynes manual (#3982) Diesel engine in car repair procedures.
From Haynes
From Haynes
Turbocharger lubrication pipe
Engine side 30 Nm, 22 lbf.ft
Turbocharger side 20 Nm, 15 lbf.ft
Reason: Image rotation corrected
