Engine immobilised
x 1061
Re: Engine immobilised
Unread post by wheeler »
Part no 6500Y1 & still showing available.
alanlondon
x 5
Unread post by alanlondon »
wheeler wrote: 06 Jul 2022, 21:32 Part no 6500Y1 & still showing available.
Thanks.
I'll check first thing in the morning.
alanlondon
x 5
C5 1800 petrol?
x 1061
Yes, from your VIN.
alanlondon
x 5
wheeler wrote: 06 Jul 2022, 22:31 Yes, from your VIN.
Yes, you are quite correct, the part is available.
Told by the dealer a few days ago NLA, now told next day delivery from PSA!
Ordered, can't be bothered pulling the existing apart!
Thanks for all your help so far.
x 1955
Unread post by Paul-R »
Sounds like you have the same problem I had many years ago on our 2001 Xsara Estate. I never did find out what exactly the problem was and bypassed the fusebox to feed the pump directly with a new fused supply.
viewtopic.php?t=27748
The bypass was still working fine when we got rid of the Xsara in 2017.
x 1061
I suspect this is just a failed internal relay. Your Xsara was the older setup with an external Double relay. I can almost guarantee your Xsara was a high resistance in the supply to to the double relay. Normally caused by a bad connection at one of the big round connectors behind the ECU, i have had to do this repair more times than I could count. I normally run a new supply to the relay. The telltale sign if this is the problem is you measure the voltage at the fuel pump & there is round about 12v but if you check it with a bulb there is not enough current to light the bulb.
P.S. You should never bypass a fuel pump relay (with the exception of testing) as it could be potentially dangerous in the event of an accident or severed fuel line.
alanlondon
x 5
Eventually fitted the new part yesterday.
Instant start and back on the road.
Thanks for all your help wheeler; most appreciated.
