Engine immobilised
- x 1056
Re: Engine immobilised
Part no 6500Y1 & still showing available.
alanlondon
- x 5
Thanks.
I'll check first thing in the morning.
alanlondon
- x 5
C5 1800 petrol?
- x 1056
Yes, from your VIN.
alanlondon
- x 5
Yes, you are quite correct, the part is available.
Told by the dealer a few days ago NLA, now told next day delivery from PSA!
Ordered, can't be bothered pulling the existing apart!
Thanks for all your help so far.
- x 1938
Sounds like you have the same problem I had many years ago on our 2001 Xsara Estate. I never did find out what exactly the problem was and bypassed the fusebox to feed the pump directly with a new fused supply.
viewtopic.php?t=27748
The bypass was still working fine when we got rid of the Xsara in 2017.
- x 1056
I suspect this is just a failed internal relay. Your Xsara was the older setup with an external Double relay. I can almost guarantee your Xsara was a high resistance in the supply to to the double relay. Normally caused by a bad connection at one of the big round connectors behind the ECU, i have had to do this repair more times than I could count. I normally run a new supply to the relay. The telltale sign if this is the problem is you measure the voltage at the fuel pump & there is round about 12v but if you check it with a bulb there is not enough current to light the bulb.
P.S. You should never bypass a fuel pump relay (with the exception of testing) as it could be potentially dangerous in the event of an accident or severed fuel line.
alanlondon
- x 5
Eventually fitted the new part yesterday.
Instant start and back on the road.
Thanks for all your help wheeler; most appreciated.
