What kind of eolys?
LedZep
x 30
Re: What kind of eolys?
Unread post by LedZep »
GiveMeABreak wrote: 22 Oct 2024, 19:35 I can't advise as to whether Powerflex and Extend can be mixed, but I would remove any you have added and refill with Extend if you can to be on the safe side.
I didn't fill anything yet.Extend is not available from the store i ordered Powerflex at the moment, so i have to wait for the right stuff.Thanks.
x 6954
Ok, I understand, then just wait for the correct stuff - as long as it isn't running dry you should be ok for a bit with careful use, as only a small amount is injected into the fuel tank.
My advice is don't fill the tank with small amounts of diesel - make sure you fill the tank up, so there's less chance of injecting more additive with smaller fuelling operations.
Rosian Drashkov
Unread post by Rosian Drashkov »
Hi everyone,
I have a 2014 Citroën DS5 with a 2.0 BlueHDi engine (Euro 6). The service light came on, and the FAP app indicates that the calculated additive level is below the critical threshold. I know this car uses Eolys fluid, but before I get out in the cold and rainy weather to check under the car, I wanted to confirm here if I’m about to purchase the correct type of Eolys. From what I’ve read, it should be Powerflex, but I’d really appreciate any advice.
Thanks in advance!
x 6954
You need Powerflex Additive (Reservoir, not a Pouch system).
ashleighx96
Unread post by ashleighx96 »
Hi hoping someone can help me out I have a Peugeot 508 2014 1.6, just wondering if anyone can help me out with which fluid I need?
My VIN number is VF3**************[VIN obfuscated, can be read by forum staff]
Matthewg_334
New User
Unread post by Matthewg_334 »
Hi I'm looking to find out what eolys fluid I need
I believe this number has something to do with the type I need 10658 I've tried to research as much as possible but no luck.. I really hope can help
x 1056
Unread post by wheeler »
Matthewg_334 wrote: 01 Mar 2026, 14:20 Hi I'm looking to find out what eolys fluid I need
What is the RP number from your tyre pressure label sticker? e in the picture.
x 1052
Unread post by Rp0thejester »
Are you suggesting Eolys fluid can be found out by checking the door sticker!? If so I'm in luck!
x 1056
Not directly, its to do with build date. The RP number gives the exact build date of the car.
