Leaky HP Pump
x 5671
Re: Leaky HP Pump
There's a recent thread with that info in it Roger - IIRC it was 7mm.
ETA: Thread here.
isisalar
x 3
Re: Leaky HP Pump
Unread post by isisalar »
It's permanently fixed in a holding cradle about the size of a 1p coin, the ball is about 4mm I would guess. Hopefully it's still in there. A post Mandrake put up had an excellent diagram of the pump which shows them clearly. I forgot to put mine on low and lost 3 litres of LHM when I did this job recently, you'll love the result when you've done it. On full flow the ball bearing and cradle did rise up a bit but didn't fall out. The second one, after the flood had abated remained firmly in place. If one has come out study that diagram to make sure it's not fitted upside down when you re assemble
Start saving for an alternator.
Good luck
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
Mandrake
x 695
Re: Leaky HP Pump
Unread post by Mandrake »
You mean this one ? :)
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
isisalar
x 3
Re: Leaky HP Pump
That's the one Simon. Thanks.
Rothgar, in the diagram you can see the ball and cradle under the spring. Hope you get it sorted out.
Cheers
Paul
Rhothgar
(Donor 2026)
x 221
Re: Leaky HP Pump
Unread post by Rhothgar »
Luckily had a spare pump. So twagged the ball bearing from that one.
I remember turning the cylinder upside down (not having stripped one down before I did not realise the bearing was in there).
It's tiny. Probably 2 / 3mm.
Rhothgar
(Donor 2026)
x 221
Re: Leaky HP Pump
Problem was I had to get Sylv to drive 30 miles to get it to me.
