206cc to a 308cc How ? Why ? Everything 308cc
x 2358
Re: 206cc to a 308cc How ? Why ? Everything 308cc
Unread post by MattBLancs »
Huskyxantia wrote: 29 Jul 2026, 21:56 So from this August your car will be photographed during the MOT , what the heck is going on ...
PaulC5 wrote: 29 Jul 2026, 22:04 ... provides additional evidence that a vehicle was present at the garage at the time of its test.
Think this is the main thing, instances of extremely dodgy MOTs where the car "subject to the inspection" hadn't actually ever been on the tester's ramp!
Huskyxantia
x 921
Unread post by Huskyxantia »
Wonder what the photo bomb ones will look like just wondering if it's got anything to do with a spray you can buy that stops the speed cameras getting a photo of your number plate ?
:-D
x 8422
Just imagine if Evri took over the job of carrying out MoTs. They could do as they currently do for parcels: take a photo of your car on a random MoT ramp somewhere and you have to guess/deduce which garage the car is actually in...
And then, at the end of every month, all their 'lost' cars end up at a boot sale somewhere - all with 12 months' MoT...
Huskyxantia
x 921
Don't forget them parcels they throw around , just picture all these cars being tossed up your front pathway and landing on the roof of the neighbours house or someone's swimming pool
:-D
x 8422
Huskyxantia wrote: 31 Jul 2026, 08:37 Don't forget them parcels they throw around , just picture all these cars being tossed up your front pathway and landing on the roof of the neighbours house or someone's swimming pool
:lol: :lol:
Huskyxantia
x 921
Ai log report
Peugeot 308cc — Maintenance Addendum
​Vehicle: Peugeot 308cc
Registration: AK60 PDU
Date: 31 July 2026
Odometer Reading: 152,664 miles
​5. Rear Brake System Servicing & Underbody Maintenance
​Rear Brake Pad Replacement:
​Removed worn rear brake pads and thoroughly cleaned the carrier slides and hardware.
​Installed a fresh set of rear brake pads to both sides.
​Caliper Piston Service:
​Retracted and wound back the threaded rear caliper pistons completely to accommodate the full thickness of the new brake pads.
​Checked piston dust boots and slider pins for proper movement and smooth operation.
​Underbody Rust Prevention & Protection:
​Prepped and applied a rust-proofing/protective treatment to both rear caliper housings.
​Treated both rear trailing arms with rust inhibitor to prevent surface corrosion and preserve the structural integrity of the rear suspension setup.
Also had to purchase this https://ebay.io/m/RiUlmk
As my one had lost the strap and is hanging rather lose , photos will follow.
As for rust proofing this https://share.temu.com/99CO5SAS7EB is amazing
:-D
Huskyxantia
x 921
So what i thought was just one hanger snapped off turned out to be both on the rear box so ive cleaned up the area aswell and sprayed some stone chip
Undone the nuts with the rattle gun , less likely to snap as its fast , cut the old rubber bits off there exhaust bits and its all clean and ready for when the 2 new ones arrived Monday. I've also repaired the hear shield too as we all know how these can fail don't we.....
:-D
x 2358
Caught just in time there Husky - are you cleaning up and treating the full length of that, err, chassis leg section?
I'd give those threaded studs a good wire brush then there's less muck and corrosion for the nut to ride over/through
Huskyxantia
x 921
Oh yes there all clean now I will get more afrer shots after these new hangers have been fitted just waiting on the courier. I have wire wheeled lots of surface rust too . I've sprayed plus gas over the bolt threads so when the hangers are put back on the nuts will go on nicely
:-D
Huskyxantia
x 921
Still waiting for the parts to arive Grrrrrr
:-D
x 1077
Unread post by Rp0thejester »
Evri are notoriously bad with delivering parcels. As for photos of the car at the MOT station I think that's more of a ' let's practice now' before we whack the road tax on electric vehicles in 2028.
Huskyxantia
x 921
So both hangers / brackets arrived yesterday afternoon and today was a free day for me. Got them fitted was a bit of a faff but got there in the end pattern parts , you know ...
I did more rust proofing too photos to show
Also investigating the diesel smell lead me to the leak over pipes and one o ring that had split so that got swapped out to. Photos to show...
Aswell as another look at the 02 sensor giving a fault of open circuit so I swapped it with another new one , guess what same thing , then compare the old to the new gave me the answer the plug is fatter and 2mm longer so I think its not connecting correctly so that is now left for another day , check out the 02 photos and look at the length of the looms !
Also fitted 2 new rubber grommets to the air box and glued them with gorilla glue then when it dried box back where it belongs and no more wobble bouncy box !
:-D
x 8422
Good work Husky!
Huskyxantia
x 921
Always amazes me how much pressure them little rings deal with
:-D
Huskyxantia
x 921
Inspection of the cars original 02 sensor shows one pin suffering corrosion the plan is now check the plug again to the car then clean if needed, I'm out in the car now 34 mile run no issues ar all , didn't smell fresh diesel either .. update later.
The original 02 sensor with green stuff...
:-D
