- x 2337
Matching and also as long as the (2) originals!
- x 8368
Perfect
- x 2337
Definitely "less wrong" which will do for me
Trip to Halfords whilst the weather has made another turn for the worst. Oil filter picked up plus a (free) swap of the 3/8" drive 7mm bit I broke on a brake job maybe 12 months ago! It's been on the "when I remember and am next going to Halfords" memory test list since then!
- x 8368
That's one good thing about Halfords... They still sell some top-quality tools and there's never a quibble if you break one.
- x 2337
- x 8368
Well, that's just mean and pettyMattBLancs wrote: 26 May 2025, 17:13 There is only one fly in the ointment really -
The "lifetime guarantee on socket sets" excludes one key item...
- x 2337
Ah well, after fairly quickly snapping in half, it's not degraded much further. I have seen replacement boxes on eBay - unfortunately Halfords keeps rearranging what you get in their 150 piece set, so matching up a set with the right recesses - problematic.
And also, if I'm buying something, I'd probably put money into a decent steel box instead
- x 2337
So I could do with about 30 minutes dry to get the grey 308 finished off.
So obviously, Sod's Law in full effect and instead I've been given increasingly heavy rain all afternoon! Bugger!
Umbrella and bonnet low (on an offcut of timber rather than its stand) has given relatively dry to swap the oil filter then add most of the new oil (Mannol, "from stock"
Jumping under the car gave a much less dry environment where rain seemed to pour down from numerous locations continuously. Sump plug tightened (new sump is 12 mm bolt - why!?!) ahead of oil topping up mentioned above.
Undertray back on.
It's ready for back on the ground and final oil level checking, but pretty soaked I've given up and come inside for tea.
Alexa said "rain stopping at 6pm"
Then when asked again about half an hour ago she then said
"stopping at 10 PM"
So I've decided not to risk asking her a third time!
Undertray back on.
"stopping at 10 PM"
- x 8368
I'm praying it stays dry for the next hour or so Matt, I'm out doing TT race photography this evening. Fingers crossed for it to stay dry for you too
- x 2337
Not a chance in Lancashire, Jim, hope you faired better!
- x 8368
Remarkably I did Matt! I seemed to choose the only spot in North Bucks that remained dry. After that, I really should do the lottery tomorrow...
Despite being dry, it was cold and windy - not like early summer at all...
The spot I chose - note angry clouds in the distance...
- x 2337
Strawberry looking very clean there Jim
- x 8368
She was Matt, after last evening she now needs a good bath!
- x 2337
Blue 308 SW, filled up yesterday,
540 miles
£55.59, 134.7 ppl, = 41.27l = 9.08 gallons
59.5 MPG (identical to last tank full)
Not had chance to scan for fault codes as yet (and fault not returned recently) nor chance to give the poor thing a wash!
540 miles
- x 2337
Adblue topped up again today - 3.5 litres approximately. Will note down the mileage tomorrow then can again calculate an Adblue/mile consumption rate to compare with the aboveMattBLancs wrote: 02 Feb 2025, 19:57Yes me too!CitroJim wrote: 02 Feb 2025, 17:18I'm intrigued by AdBlue consumption Matt. Mine seems to use hardly any and in my ownership I've yet to need to top up the AdBlue tank...MattBLancs wrote: 02 Feb 2025, 10:57 Last part of the service, top up of the adblue. Doesn't seem long since I did it, but still swallowed 2.5 litres. Wynns additive also in there too.
Quote me from a while back:That equates to Adblue consumption of 3,204.7 miles per (adblue) gallon.MattBLancs wrote: 24 Aug 2024, 11:31 Adblue, tank holds 17 litres [ = 3.74 UK gallons ] and the book suggests that's only 12,000 miles worth!
I've topped up again today, 2.5 litres, full now and was last top up too.
140098 miles now, approx 134500 miles last time = 5,598 miles
5,598 / (2.5 / 4.54) = 10,165 miles per (adblue) gallon.
Or, in short, not enough to get a meaningful comparison with the book figures!
So far, chucking it in whenever I get chance. I was very keen to get some of the Wynns anti-crystalisation additive in there, hence brimming the tank (plus enough additive to treat the full 17 litre tank capacity) as soon as I got the car.This week, Diagbox told me I still had 4500Km to go before topping up was needed. I've done around 10,000 miles so far on what was in the tank when i bought the car...
Do you wait for the warning and then top-up or as and when it seems like a good plan?
Servicing this weekend seemed a good opportunity to see where it was up too. Though I said it didn't seem long between fills and I was quite surprised it took 2.5 litres, I'm also surprised it's as much as 5,500 miles covered too!
Yes, Wynn's Crystal Clear and Protect dosed in with the adblue every time is the plan for me.Should we await the warning and only top-up then? Also, do you use any anti-crystallisation additive?
I intend to take the injector out the exhaust for a quick look at some point (a summer job, definitely!) but nothing to suspect impended doom at present!
I've read this thread about tank / pump "failure" (actually proven to be pressure sensor failure) with keen interest:
viewtopic.php?t=81429&start=30
I'm also considering buying the various parts used as the fix and keeping them ready in case I suffer the same fate.
Edit: 143842 miles.
Screen wash also topped up, consumption rate of that = not calculating at present!
