PSA NAC RCC Updates
This is the Connected NAV system.
Main Features: It is a fully integrated Telematics System featuring CarPlay, Android Auto, Real Time Services, Voice Commands, High-Res Display, 3D Navigation, Bluetooth Hands Free & USB. 2 versions of the system are available NAC (Navigation Audio Connectée) and RCC (Radio Couleur Connectée) or Connected Colour Radio, which does not have the Integrated Navigation or Live Services.
denis1304
Re: PSA NAC RCC Updates
Unread post by denis1304 »
Solarriors wrote: 07 Sep 2026, 06:31
denis1304 wrote: 04 Sep 2026, 08:22 I'm sorry, but I don't quite understand what you mean by saying, "Remember that you cannot install just one country that you didn't select in any previous installation - you've to reinstall all of the countries you want."
It means you cannot add countries piece by pieces after one installation. Every installation combination replaces entirely the previous installation. You have to install the full combination you want at once.
I would like to meet the person who decided this and ask them what they were thinking.
If you want to update all the countries that came with the car, you would need to run the car for 8 hours (if it would be enough), or you need to lose countries you think you don't need?
I would rather have some slightly out-of-date map than no map at all.
dimonito
x 3
Unread post by dimonito »
Hello
I got my nac upgraded to wave4 by installing version 42.03.33.42 and I could not install maps after that for several month. Now the Peugeot app showed me 2 available updates - version 20 maps which I installed immediately and version 44.06.44.22 nac firmware which says "hardware is not compatible". As I understand I should download version 44.07.33.32 manually and generate a license key via majestic server using uin from my head unit.
Could you please describe the process step-by-step so I could make everything right?
rui_saraiva
x 65
Unread post by rui_saraiva »
@denis1304: It will take about 1 hour to install the maps for all the countries. The installation process needs to decrypt and verify the SHA256 checksums of all the files on the USB flash drive, regardless of the number of countries you selected. That is the most time-consuming step. If you select just a few countries, it will finish just a few minutes faster.
@dimonito: The firmware version 44.06.44.22_NAC-r0 that is currently offered (since January) by the official Update software has an expired signing certificate and is impossible to install. In the USB flash drive prepared by the official software, what is the filename of the file in the "\license" folder (should be "license_xxxxxxxxxxxxxxxxxxxx_001315031671116172.key")?
Regards,
Rui Saraiva
All NAC, CRONY2, AIO, RCC & RCE updates: https://sites.google.com/view/nac-rcc
dimonito
x 3
rui_saraiva wrote: 09 Sep 2026, 04:13 @denis1304: It will take about 1 hour to install the maps for all the countries. The installation process needs to decrypt and verify the SHA256 checksums of all the files on the USB flash drive, regardless of the number of countries you selected. That is the most time-consuming step. If you select just a few countries, it will finish just a few minutes faster.
license file nam is license_0D01241681D4EE7F9595_001315031671116172.key
rui_saraiva
x 65
@dimonito:
Copy this license key
https://majestic-web.mpsa.com/mjf00-web ... D4EE7F9595
to a "\license" folder in a USB flash drive with the 44.07.33.32_NAC-r0 firmware version (UpdateID 001315031692686757).
Regards,
Rui Saraiva
Deermand
x 4
Unread post by Deermand »
I have a factory Wave 3 unit, which I managed to update to version 42 over a year ago, I think. However, the servers still recognized it as a Wave 3. I checked again today, and suddenly my radio is being recognized as a Wave 4, and the update to version 44 is now available for download!
You can also download just the license for version 44.07.33.32_NAC-r0.
x 1942
Unread post by Paul-R »
rui_saraiva wrote: 09 Sep 2026, 12:42 @dimonito:
The forum software has truncated the key for display and simple copy and paste won't work.
In order to see the full key go through the motions of replying with a quote (click the the quote mark up near the heart icon) and then you can see the key in full to copy.
When you have copied the key simply close the window down or click or tap to go back depending on how you're reading the post.
Solarriors
x 7
Unread post by Solarriors »
Didn't someone manage to update by changing back the date on the car ?
dimonito
x 3
Done!
Thanks a lot!
_LCLM_
New User
Unread post by _LCLM_ »
How to prepare an update pen for the latest version of the European cartography map 20.0.0-r0 (11 Mar 2026), for my NAC_EUR_WAVE4 (508 SW 1.6 plugin - 2021)
Solarriors
x 7
So apparently it's possible to change the user's country by telecoding in a NAC Wave 2?
owl
x 15
Unread post by owl »
@rui, I wanted to check automatic vin identification on your site but I think it doesnt work. Could you please check it? Thanks in advance.
Sergio Ribeiro
Unread post by Sergio Ribeiro »
Hello,
I have a Citroën C5 Aircross Hybrid (2023), currently running NAC firmware version 43.04.26.52_NAC-r0 (from 2021-07-02).
VIN (partial, masked for privacy): VR7**************[VIN obfuscated, can be read by forum staff]-XXXXXX
Using the system identification tool, this comes back as NAC_EUR_WAVE4.
I've tried updating via both methods, neither works:
1. USB (via files generated by the official MyCitroën app): the update to 44.07.33.32_NAC-r0 is offered and does get transferred to the car, but fails during installation with "Version not compatible with hardware".
2. OTA via the app (the "complete activation of connected services" flow - 10 min engine running, then 5 min locked): this doesn't even appear to attempt a download - no progress is ever shown, it just goes back to the same "activation required" prompt every time, regardless of connectivity. My guess is the car requests the file from the server and gets an invalid response before any installation attempt can even start, which would be consistent with the file itself being broken server-side rather than a connectivity issue on my end.
I understand from this thread that this is the known Feb 2026 signing certificate issue affecting NAC_EUR_WAVE4 systems.
Could you point me to the correct "old valid" firmware file and matching license (UpdateID/MediaVersion) for my system, so I can prepare the USB manually? Happy to provide any further details needed.
Thank you in advance.
incommunicado
Unread post by incommunicado »
Did you solve it? I face the same issue
Sergio Ribeiro
Not solved yet on my end, still waiting to hear back.
