Citroen Dispatch language set to French
Kwaka
Re: Citroen Dispatch language set to French
Unread post by Kwaka »
xantia_v6 wrote: 31 Jul 2024, 15:19 A couple of comments:
The RD4 came with different front panels for different PSA models, if thinking of a permanent installation, then at least check that the width and panel colour match your facia.
The installer of the aftermarket radio may have discarded the original mounting hardware behind the dash
For a temporary install (just to change the language) you don't need to have the radio coded.
Ahh thank you. Yes thats probably a better option. Buy an OEM radio, use it to set the language etc and then put back the nicer stereo that’s been fitted. I guess if the battery is disconnected everything reverts to French again.
x 1481
Unread post by xantia_v6 »
That is a good question, the settings should survive a battery disconnect. Cross fingers that they also survive if the RD4 is removed. I think it likely to be OK
x 6950
Though it does make me wonder how it reverted back to French unless the owner was French?....
moizeau
x 423
Unread post by moizeau »
GiveMeABreak wrote: 01 Aug 2024, 00:35 Though it does make me wonder how it reverted back to French unless the owner was French?....
My Dispatch does. No idea why, I just change it back.
Pete
