No problem, good luck.
Most of the hardware codes are on our wiki in sections numerically ordered:
https://frenchcarforum.co.uk/wiki/Elect ... ring_Codes
Citroen C5 iii 2009
- x 6957
Re: Citroen C5 iii 2009
davidm3836
Good evening all, I have brought this thread back to life as I have an update. After trying the replacement BSM & ABS Module I ended up with the same issue. Braking System Faulty and the car failing to start, blanking out the milage on the car and blocking comms to the car via the OBD socket. I have had to bite the bullet and take it to an auto electrician and he has (after 6 expensive hours) found the fault. Turns out to be a faulty power steering pump fault. Getting poor CAN reading from the module.
So Marc, I know you have awesome and wonder if you would know the power steering pump serial number so I can try and order one as the mechanic said better to try and source an aftermarket or second hand unit as they are expensive?
I think im almost at the end of this journey. Fingers crossed anyway. Thanks all
- x 6957
Ok, so I can help with part numbers, but please see the following:
If you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future parts requests for up to 2 years, so excellent value.
If interested, links are below (I already have your VIN).
I should also add that the part number has been changed and on top of that there is a modification that is required concerning the electrical harness. I can provide you with the revised parts and technical changes for you as part of the above.
Jay-Bruce
- x 280
Just chiming in to say that I'm >99% marc has access to the answer, but that information will come from the forum's paid for and very expensive access to the official PSA/Stellantis technical information service(s), hence him asking you to "donate". Compared to your 6hrs at an auto electrician, a £10 donation is a drop in the ocean so well worth a "punt", especially since as this forum was founded by enthusiasts, for enthusiasts, and is ran by its members as a not for profit, I'm willing to underwrite your donation, in that if you can prove to me that Marc drew a blank on your request for a part number I'll Paypal you the ten bucks.
