| Vehicle Characteristics | |
| Vehicle family | C3 (B618) |
| AS/RP N° | 16180 76 1 0647 |
| Warranty Start Date | 22/05/2021 |
| Engine serial number | 10 Q4DF 0010394 |
| OPB | 00K8 |
| BER | e2*2007/46*0003*64 |
| P4A | 9836948399 |
| General Information | |
| PRODUCT TYPE | PASSENGER CAR |
| COMMERCIAL MARQUE/COMPONENT TYPE | CITROEN |
| VEHICLE FAMILY | C3 (B618) |
| SILHOUETTE | 5-DOOR SALOON |
| TRIM LEVEL | MEDIUM MEDIUM |
| ENGINE | DV5RCF/UE63 1.5L DIESEL |
| TRANSMISSION | STT TYPE 6-SPEED MANUAL GEARBOX |
| PAINT TYPE | NON-METALLIC PAINT |
| BODY COLOUR | EWP - BANQUISE WHITE PAINT |
| INTERIOR TRIM TYPE | CLOTH WARP AND WEFT CURITIBA "23" |
| UPHOLSTERY COLOUR | "FR" |
| GEARBOX (CHARACTERISTICS) | MB6GW |
| CONVERSION GUIDANCE | WITHOUT CONVERSION |
| DEFINITION TO FOLLOW | MID-LIFE |
| ENGINE (TYPE) | DV TYPE ENGINE |
| ROOF (EXT. ASPECT) | BODY COLOUR ROOF |
| OTHER BADGE | WITHOUT FULLER BADGE |
| OTHER BADGE, " MISC. " | WITHOUT FULLER BADGE |
| BADGE | FAMILY BADGE |
| SPEEDOMETER DRIVE | WITHOUT SPEEDOMETER RATIO |
| Fuel Supply-Engine | |
| FUEL SUPPLY | DIRECT EXCHANGER TURBO INJECTION |
| FUEL FILLER CAP | FUEL TANK CAP AUTOMATIC LOCKING |
| DIESEL FILTER WATER DETECTOR | WITHOUT DIESEL FILTER WATER DETECTOR |
| FUEL | DIESEL GRADE DA/DE/DE+ |
| EMISSIONS STANDARD (ENGINE) | EURO 6.3 ENGINE EMISSION CONTROL |
| CAPACITY | 1500 CM3 |
| FUEL TANK | FUEL TANK WITH LOCATING TAB |
| OPTIMISATION OF VEHICLE’S CONSUMPTION | NORMAL FUEL CONSUMPTION OPTIMISATION |
| COOLING MOTOR | RADIATOR TH : 18 - 21 DM2 BRAZED ALUMINIUM |
| CRANKCASE GAS CIRCUIT HEATING | WITH HEATER CASING GAS CIRCUIT |
| POWER VARIATION (ENGINE) | 75KW - 250NM |
| SPECIAL POWER TRAIN SOUND | WITHOUT POWER TRAIN ACOUSTICS |
| EOBD SELF-DIAGNOSIS SYSTEM | "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER |
| DEVICE (ANTIPOLLUTION) | EXHAUST GAS RECYCING "EGR" + EXCHANGER |
| VEHICLE TECHNICAL DEPOLLUTION | EURO 6.3 VEHICLE TECHNICAL EMISSION CONTROL |
| PARTICLE FILTER | WITH PARTICLE EMISSION FILTER |
| FAN | 1 AERO 2-SPEED 140W FAN WITH SCOOP |
| FUEL VAPOUR RETRIEVAL | WITHOUT PETROL VAPOUR RECUPERATION |
| INJECTION ASSOCIATED VARIANT | MOUNTING BOSCH |
| DRIVE TRAIN | INTERNAL COMBUSTION DRIVE TRAIN |
| STOP AND START | WITH STOP AND START STARTER |
| Gearbox Transmission | |
| FINAL DRIVE RATIO | AXLE RATIO 19 X 72 |
| WHEEL STYLE | 15 INCH STEEL WHEEL |
| SEAL, WHEEL END | WHEEL-SIDE SEAL RZ 17.5 |
| SEAL, DIFFERENTIAL END | AXLE-SIDE SEAL JB2T |
| DIFFERENTIAL (GEARBOX) | 84 DIAMETER DIFFERENTIAL |
| RIM/TYRE SIZE | 15 INCH TYRE FITMENT |
| TYRE (SIZE, TYPE) | 185/65 R15 88T NON REINFORCED TYRE |
| WHEELS FITTED | 6" RIM ROAD WHEELS |
| WHEEL (TYPE) | MOUNTING OPTIMIZED STEEL WHEEL |
| INFLATION PRESSURE LOSS INDICATOR | INDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION |
| GEARBOX TYPE | MB6 TYPE GEARBOX |
| Suspension-Steering-Brakes | |
| ABS | WITH ABS BRAKES |
| REAR ANTI-ROLL BAR | WITHOUT REAR ANTI-ROLL BAR |
| FRONT ANTI-ROLL BAR | FRONT ANTI-ROLL BAR DIAM 20 |
| BRAKE TYPE | VENTILATED FRONT DISCS/REAR DISCS |
| STEERING WHEEL ANGLE | WITH STEERING ANGLE SENSOR |
| SUSPENSION | NORMAL SUSPENSION |
| DYNAMIC STABILITY CONTROL SYSTEM | ELECTRONIC STABILITY PROGRAM |
| BRAKE ASSOCIATED VARIANT | BOSCH 9.0 ESP |
| STEERING (OPERATION) | ELECTRIC POWER STEERING |
| ELECTRIC STEERING | 90 AMPERES ELECTRIC STEERING |
| PEDAL BRACKET (TYPE) | PEDAL STANDARD |
| Body Fittings | |
| TOWBAR | WITHOUT TOWBAR |
| AERIAL | AERIAL + GPS |
| FINISHER (SELF-ADHESIVE) | FR+RR TRIM MATT BLACK SURROUND |
| SIDE MOULDINGS (TYPE) | WITHOUT LATERAL PROTECTORS |
| SIDE MOULDINGS (DIMENSION) | WIDE LAT PROTECTIONS + WING+SILL EXTENSIONS |
| WHEEL EMBELLISHER (STYLE) | 15 INCH MONT BLANC STYLE WHEEL TRIM |
| UNDERBODY SHIELD | DEFLECTOR UNDER FRONT FLOOR |
| REVERSING LAMPS | WITH 1 REVERSING LIGHT |
| INDICATORS | LUMINOUS SIGNATURE |
| ADDITIONAL SHIELD (UNDER ENGINE) | W/O ENGINE UNDERSHELDING |
| EXT. LOAD RETENTION RING (ATTACHMENT) | WITH DETACHABLE EXTERIOR LASHING RING |
| EXT. REARVIEW MIRROR COMP. FUNCTION | ELECTRIC FOLDING EXTERIOR MIRROR |
| ENGINE BAY SOUNDPROOFING | SOUNDPROOFING UNDER BONNET + BULKHEAD + POWER TRAIN |
| WINDSCREEN WIPER | FRONT WIPER BLADE WITH RAIN SENSOR |
| REAR SCREEN WIPER (OPERATION) | INTERMITTENT REAR SCREEN WIPER |
| FRONT PANEL BLANK | PLUG FRONT FACADE |
| ROOF GLASS | WITHOUT ROOF WINDOW |
| OUTSIDE TEMPERATURE SENSOR | WITH EXTERNAL TEMPERATURE SENSOR |
| NUMBER PLATE | WITHOUT LICENCE PLATE |
| FRONT FOGLAMP | FRONT FOG LIGHTS |
| EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) | ELECTRIC DRIVER’S EXTERIOR MIRROR |
| EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) | PASSENGER ELECTRIC DOOR MIRROR |
| SPARE WHEEL | WITHOUT SPARE WHEEL |
| EXTERIOR ACCESSORIES | BODY COLOUR EXTERIOR HANDLE |
| EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) | CURVED EXTERIOR MIRROR GLASS |
| BUMPER TRIM | GLOSS BLACK FOGLAMP TRIM |
| GLASS (APPEARANCE) | WINDOW TINTED |
| HANDS FREE ACCESS AND STARTING | WITHOUT HANDS-FREE ACCESS/STARTING |
| Interior Fittings | |
| SIDE ARMREST (TYPE) | FRONT REAR SIDE ARMREST + PULL HANDLE A |
| ANTI-THEFT ALARM | WITHOUT THEFT PROTECTION ALARM |
| FRONT HEAD RESTRAINT | FRONT HEADREST ADJUSTABLE |
| REAR SEAT | REAR BENCH SEAT SINGLE CUSHION SEPARATE SEAT BACKS |
| BLIND SPOT DETECTION | WITHOUT BLIND SPOT MONITORING |
| LUGGAGE COVER | SHELF |
| REAR SEATBELT | 3-REEL, 3-POINT REAR SEAT BELTS |
| FRONT SEATBELT | RETRACTOR ALARM DRIVER + PASS S/BELT |
| CLIMATE (AMBIENT TEMP) | TEMPERATE COUNTRIES |
| CHILD LOCK | MANUAL REAR CHILD LOCK |
| SPEED GRADUATIONS | SPEED GRADUATION IN KM/H |
| GRAB HANDLES | HOOKS |
| RADIO EQUIPMENT | FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER |
| DRIVING POSITION | LEFT-HAND DRIVE |
| MIRROR LINK | WITH MIRROR LINK |
| BOOT AND LOAD SPACE LIGHTING | LOAD VOLUME + BOOT LIGHTING AUTO CONTROL |
| DASHBOARD EQUIPMENT | BRIL BLACK CAPPING+MIUM GREY DECORATION |
| MISC. INT. LAMPS | FRONT SPOTLAMP |
| LOAD SPACE TRIM | BOOT CARPET MAT |
| INSTRUMENT PANEL (CHARACTERISTICS) | LCD INSTRUMENT PANEL + TEXT |
| CHILD SEAT ANCHORING POINTS | WITH REAR ISOFIX, WITHOUT FRONT ISOFIX |
| LOUDSPEAKER | 4 FR SPEAKERS (2 TW + 2 FR)+2 RR SPEAKERS |
| RADIO CONTROLS | STEERING WHEEL AUDIO SYSTEM CONTROL |
| POLLEN FILTER | WITH POLLEN FILTER + ACTIVATED CARBON |
| PASSENGER COMPARTMENT SOUNDPROOFING | SOUNDPROOFING BULKHEAD+CDG FR FLOOR+ABS WHEEL ARCH |
| FRONT PASSENGER SEAT HEIGHT CONTROL | WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT |
| DRIVER SEAT CONTROL | MANUAL DRIVER’S SEAT CONTROL |
| FRONT PASSENGER SEAT CONTROL | MANUAL FRONT PASSENGER SEAT CONTROL |
| DRIVER SEAT ADJUSTMENT | DRIVER’S FR SEAT CUSHION ADJUSTMENT ADJUSTABLE BACKREST |
| FRONT PASSENGER SEAT ADJUSTMENT | ADJUSTMENT FRONT PASSENGER SEAT CUSHION RECLINING SEAT BACK |
| FRONT SEAT ARMREST | ASSEMBLY WITHOUT FRONT ELBOW REST |
| COMPACT DISC | WITHOUT COMPACT DISC |
| SATELLITE NAVIGATION SYSTEM | WITH NAVIGATION SYSTEM COLOUR SCREEN |
| HEADLAMP BULBS | ECO LED |
| REAR WINDOW LIFT | MANUAL CONTROL REAR WINDOW |
| TRAFFIC INFORMATION READER | WITH LATERAL TRAJECTORY MONITORING |
| DRIVER’S WINDOW LIFT | SEQUENTIAL DRIVER’S ELECTRIC WINDOW |
| PASSENGER’S WINDOW LIFT | SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER |
| DISPLAY | GLOSSY SD DGT7C SCREEN |
| COURTESY MIRROR | DRIV OCCULT+PASS OCCULT W/O LIGHT |
| OIL GAUGE | W/O OIL LEVEL INDICATOR |
| FITTING REAR HEAD RESTRAINT | MOUNT 3 REAR HEAD-REST |
| HEATING ELEMENT | NON HEATED SEAT |
| FRONT LATERAL AIRBAG | THORAX SIDE + CURTAIN AIRBAG |
| PASSENGER AIRBAG | WITH AIRBAG ON PASSENGER SIDE |
| EQUIPMENT PACK | SPECIALIST MOTOR VEHICLE |
| EXTERIOR REAR VIEW MIRROR (HEATED) | HEATED EXTERIOR MIRROR |
| AIRBAG DEACTIVATION | MANUAL AIRBAG DEACTIVATION |
| INTERIOR DOOR CONTROL (APPEARANCE) | CHROME FINISH INSIDE DOOR HANDLE |
| COURTESY LAMP | DOORS + FR COURTESY LIGHT REMOTE CONTROL |
| REAR LOAD FLOOR | WITHOUT REAR LOAD FLOOR |
| FRONT SEAT GUARD | WITHOUT CAB PROTECTION PANEL |
| FRONT SUN VISOR | DRIVER’S+PASSENGER’S SIDE (WITH + W/O INSCRIPTION) |
| WIFI | WITH WIFI |
| STORAGE (DRIVING POSITION) | CLOSED FRONT PANEL STORAGE COMPARTMENT |
| RADIO RECEIVER | DIGITAL CONNECTED NAVIGATION |
| REFRIGERATION | AUTOMATIC AIR CONDITIONING |
| CRUISE CONTROL | REGULATOR AND SPEED LIMIT |
| DRIVER’S SEAT HEIGHT CONTROL | DRIVER’S SEAT HEIGHT MANUAL ADJ |
| INTERIOR REAR VIEW MIRROR | ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR |
| STORAGE (OTHERS) | W/O OTHER SETTING BOXES |
| CARPET COVER | W/O CARPETMAT |
| DRIVER AIRBAG | DRIVERS AIR BAG |
| LOAD SPACE STORAGE | W/O BOOT TIDY |
| TUNER RADIO | MONO RADIO TUNER |
| EXTERIOR TEMPERATURE (SCALE) | CELSIUS EXTERIOR TEMPERATURE INDICATOR |
| WATER TEMP INDICATOR | WATER TEMPERATURE TELL-TALE |
| OBSTACLE DETECTION SYSTEM | REAR RADAR OBSTACLE SENSOR |
| TRIM ADAPTATION | HEART OF THE RANGE GEAR LEVER KNOB+PVC GAITER |
| RADIO FREQUENCY | WESTERN EUROPE RADIO FREQUENCY |
| LOCKING CONTROL | SIMPLE CENTRAL LOCKING |
| STEERING WHEEL | RUBBER STEERING WHEEL 3 BRANCH |
| AUDIO PACK AUXILIARY SOCKET | 1 USB SOCKET |
| TELEMATIC UNIT | INDEPENDENT TELEMATIC UNIT 3S |
| Electrical | |
| ALTERNATOR | ALTERNATOR CLASS 15 UHEA |
| BATTERY | L3 760 70AH EFBC 760 BATTERY BECOMES EFBC |
| STARTER MOTOR | STTD STARTER |
| CEN. LOCKING REM CONTROL FREQUENCY | LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE |
| MULTIPLEXING | ECO ELECTRICAL ARCHITECTURE |
| BATTERY CHARGE MEASUREMENT | WITH BATTERY CHARGE MEASUREMENT |
| LIGHTING OF LAMPS | AUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING |
| Component Manufacturers | |
| Miscellaneous | |
| SPECIAL SPECIFICATION | VEHICLE FOR MODIFICATION |
| MODIF. DURING MODEL YEAR | MINOR INDEX "04" |
| CONDENSER (SPECIFICATIONS) | CONDENSER 19.2 DM - THICKNESS 12CM |
| ATMOSPHERIC CONDITIONS | NORMAL ATMOSPHERE |
| AIR CONDITIONING PIPES | STANDARD AIR CONDITIONING PIPES |
| TRAFFIC SIDE | DRIVING ON THE RIGHT-HAND SIDE |
| SET OF KEYS | 1 HIGH FREQUENCY REMOTE CONTROL KEY+1 MAIN KEY ONLY |
| REFRIGERANT | AIRCON FLUID 1234 YF |
| EMERGENCY EQUIPMENT | PUNCTURE REPAIR KIT |
| ADDITIONAL TYPE APPROVAL PLATE | W/O ADDIT HOMOLOGATION PLATE |
| SLAVE CONTROL UNIT | BSI + COM 2008 |
How to identify what model engine is in your Citroen
- x 6963
Re: How to identify what model engine is in your Citroen
Here you go:
ngorov
- New User
Hi , can I also please get help: VF7**************[VIN obfuscated, can be read by forum staff]
Thanks a lot!
Thanks a lot!
- x 6963
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
| A response to your question by a Forum Admin requiring parts or specific vehicle information requires you to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum. |
stafford52
I would love the info from my vin number Marc
vin: VF7**************[VIN obfuscated, can be read by forum staff]
Dont know if Ive got to make another donation as its been so long since I last cried for help lol....
stafford52
Just made another donation as I think the site is well worth it as it does such a good job for us guys, especially marc and his knowledgeable mates... Thank you...
- x 6963
@stafford52: Thanks for your Forum donation - but please be aware that Services ore offline at present due to merging of PSA accounts to the new Stellantis Systems and this is taking a lot of time for them to both migrate the data and fix the bugs, so as per the message in the Parts requests thread, I can't help you with this right now, but I will bookmark this post to deal with as soon as systems are back and our account has been migrated.
Thanks for your patience.
- x 6963
Ok, so back up for a while, here's your factory build sheet:stafford52 wrote: 19 Oct 2024, 19:58 I would love the info from my vin number Marc
| Vehicle characteristics | |
| Vehicle Family | C3 (A51) |
| AS/RP N° | 12223 CA 2 0791 |
| Warranty Start Date | 30/06/2010 |
| Engine serial number | 10 JBCL 3014070 |
| OPB | L00C |
| BER | e2*2007/46*0003*03 |
| P4A | 9671732380 |
| VEHICLE FAMILY | C3 (A51) |
| SILHOUETTE | 5 DOOR SALOON |
| ENGINE | TURBO DIESEL DV6DTED |
| TRANSMISSION | LONG 5-SPEED MANUAL GEARBOX |
| PAINT TYPE | METALLIC PAINTWORK |
| BODY COLOUR | EZR - PAINT ALUMINIUM GREY |
| INTERIOR TRIM TYPE | VELOUR KARL G112 + OMNI F920 ’3N’ |
| UPHOLSTERY COLOUR | "FY" |
| GEARBOX (CHARACTERISTICS) | BE4-5L MANUAL GEARBOX |
| FUEL SUPPLY | DIRECT EXCHANGE TURBO INJECTION |
| EMISSIONS STANDARD (ENGINE) | EURO 5 L6 UPPER ENGINE EMISSION CONTROL |
| CAPACITY | 1600 CM3 |
| CATALYTIC CONVERTER | 2-COMPONENT CATALYSER 50 PPM LOWER PLATE |
| OIL COOLER | WITHOUT OIL-WATER DISTR CHAMB |
| OPTIMISATION OF VEHICLE’S CONSUMPTION | FUEL CONSUMPTION OPTIMISATION |
| POWER VARIATION (ENGINE) | 68 KW - 230 NM |
| DEVICE (ANTIPOLLUTION) | "EGR" EXHAUST GAS RECYCLING |
| VEHICLE TECHNICAL DEPOLLUTION | TECHNICAL VEHICLE EMISSION CONTROL EURO 5 |
| TANK FILTER | CITHOUT RESERVOIR FILTER |
| STOP AND START | WITHOUT STOP AND START |
| FINAL DRIVE RATIO | AXLE RATION 19 X 63 |
| WHEEL STYLE | STEEL 6 J15 4-23 |
| CLUTCH | HYDRAULIC CLUTCH |
| DIFFERENTIAL (GEARBOX) | DIFFERENTIAL 84 |
| WHEEL (TYPE) | STEEL WHEELS |
| GEARBOX TYPE | GEARBOX BE4R |
| FRONT ANTI-ROLL BAR | FRONT ANTI-ROLL BAR DIAM 22 |
| BRAKE TYPE | VENTILATED FRONT DISCS/REAR DRUMS |
| DYNAMIC STABILITY CONTROL SYSTEM | WITHOUT ELECTRONIC STABILITY PROGRAM |
| BRAKE ASSOCIATED VARIANT | ABS TEVES MK70 |
| Body Fittings | |
| AERIAL | SHORT ROOF AERIAL |
| FINISHER (SELF-ADHESIVE) | MATT BLACK REAR SURROUND TRIM |
| SIDE MOULDINGS (DIMENSION) | PLASTIC SIDE SILL |
| WHEEL EMBELLISHER (STYLE) | SAM 15 INCH WHEEL TRIM |
| UNDERBODY SHIELD | PLASTIC PROTECTIO + FOAM UNDER ENGINE |
| REVERSING LAMPS | WITH 1 REVERSING LAMP |
| EXT. REARVIEW MIRROR COMP. FUNCTION | EXT MIRROR MANUAL-FOLD BACK |
| EXHAUST TAILPIPE TRIM | WITH EXHAUST OUTLET EMBELLISHER |
| ENGINE BAY SOUNDPROOFING | UNDERBONNET + BULKHEAD SOUNDPROOFING |
| WINDSCREEN WIPER | FRONT WIPER BLADE W/O RAIN SENSOR |
| FRONT PANEL BLANK | FRONT FACE LOWER CLOSER |
| BUMPER | BODY COLOUR FRONT/REAR BUMPER |
| SPARE WHEEL | STEEL WHEEL + STANDARD TYRE |
| EXTERIOR ACCESSORIES | BODY COLOUR EXT HANDLE |
| SUN ROOF | WITHOUT SUN ROOF |
| BUMPER TRIM | BUMPER WITHOUT STRIP |
| GLASS (APPEARANCE) | TINTED + DARK-TINTED WINDOW GLASS |
| WINDOW (TYPE) | CIELO LAMINATED WINDSCREEN + TOUGHENED RR SCREEN |
| CIGAR LIGHTER | WITHOUT CIGAR-LIGHTER |
| REAR HEAD RESTRAINT | REAR HEADREST ADJUSTABLE |
| REAR SEAT ARMREST | WITHOUT RR SEAT ARMREST |
| REAR SEATBELT | REAR 3-POINT 3 INERTIA REEL SEAT BELT |
| AIR CONDITIONING | AIR CONDITIONING WITH MOTORISED AIR INTAKE |
| CHILD LOCK | ELECTRIC REAR CHILD LOCK |
| SPEED GRADUATIONS | SPEED GRADUATION IN MPH |
| DRIVING POSITION | RIGHT HAND DRIVE |
| DASHBOARD EQUIPMENT | LION GREY CAPPING |
| MISC. INT. LAMPS | W/O MAP READING LAMP |
| UNDERSEAT STORAGE | WITHOUT UNDER SEAT STORAGE |
| INSTRUMENT PANEL (CHARACTERISTICS) | 210 KM/H 130 M/H BLACK BACKGR PERM LIGHTING BLC |
| CHILD SEAT ANCHORING POINTS | WITH CHILD SEAT MOUNTING WITH RR ISO |
| LOUDSPEAKER | 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS |
| RADIO CONTROLS | REMOTE RADIO CONTROL |
| POLLEN FILTER | WITH POLLEN FILTER |
| FRONT PASSENGER SEAT HEIGHT CONTROL | FRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT |
| ROOF CONSOLE | WITHOUT ROOF CONSOLE |
| SATELLITE NAVIGATION SYSTEM | WITHOUT NAVIGATION SYSTEM |
| REAR WINDOW LIFT | MAN CTRL REAR WINDOW LIFTER |
| CABIN CARPET | FRONT PASSENGER COMPARTMENT + TUNNEL CARPET |
| PASSENGER’S WINDOW LIFT | NON SEQUENTIAL FRONT PASSENGER’S ELECTRIC WINDOW |
| DISPLAY | DISPLAY (RADIO+CLOCK,T°,CD) |
| COURTESY MIRROR | WITHOUT VANITY MIRROR |
| OIL GAUGE | STD OIL LEVEL INDICATOR |
| FOOTWELL LIGHTING | WITHOUT DOOR SILL LIGHTING |
| EQUIPMENT PACK | WITHOUT DRIVING SCHOOL EQUIPMENT PACK |
| EXTERIOR REAR VIEW MIRROR (HEATED) | NON HEATED DOOR MIRROR |
| INTERIOR DOOR CONTROL (APPEARANCE) | CHROME EFFECT DOOR HANDLE + COLOURED TRIM |
| COURTESY LAMP | DOORS + FR AND RR COURTESY LIGHTS REMOTE CONTROL |
| FRONT SUN VISOR | DRIVER + PASSENGER SUN VISOR WITHOUT INSCRIPTION |
| RADIO RECEIVER | "RD4/MP3" RDS COMPACT DISC AUDIO SYSTEM |
| REFRIGERATION | SINGLE AIR CONDITIONING |
| DRIVER’S SEAT HEIGHT CONTROL | PARALLEL DRV HEIGHT ADJ |
| INTERIOR REAR VIEW MIRROR | NON-ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR |
| STORAGE (OTHERS) | PLAIN STORAGE POCKET |
| TRIM ADAPTATION | GEAR LEVER KNOB PLASTIC+CHROME INSERT |
| FLOOR MAT | W/O CARPETMAT |
| EQUALISER AMPLIFIER | WITHOUT EQUALISER AMPLIFIER |
| LOCKING CONTROL | CENTRAL DEAD LOCKING |
| STEERING WHEEL | LEATHER STEERINGWHEEL |
| DRIVER’S KNEE AIRBAG | WITHOUT DRIVER’S KNEE AIRBAG |
| AUDIO PACK AUXILIARY SOCKET | 1 JACK SOCKET + USB |
| TELEMATIC UNIT | WITHOUT TELEMATIC UNIT |
| Electrical | |
| ALTERNATOR | ALTERNATOR 150 AMP |
| BATTERY | BATTERY L2 400 |
| STARTER MOTOR | STARTER MOTOR CL 4 |
| SPECIAL LIGHTING | WITHOUT PARTICULAR LIGHT |
| LIGHTING OF LAMPS | MANUAL SWITCHING ON OF LIGHTS |
| Miscellaneous | |
| SPECIAL SPECIFICATION | STANDARD |
| VIN PLATE | EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE |
| RADIO HEADPHONE SOCKET | SINGLE ACCESSORY SOCKET |
| TRAFFIC SIDE | DRIVING ON THE LEFT-HAND SIDE |
| SET OF KEYS | 1 HF PLIP KEY + 1 SINGLE MAIN KEY |
| EMERGENCY EQUIPMENT | W/O HELP EQUIPMENT |
| SURFACE CONDITIONS | GOOD TERRAIN |
| SPEED MONITORING | WITHOUT SPEED CHECK |
| SLAVE CONTROL UNIT | BSI + COM 2005 4-POSITION RING |
| EMERGENCY WARNING TRIANGLE | WARNING TRIANGLE CONDITIONNING |
stafford52
You are an absolute star Marc....
krio1987
- x 4
Hi there Would you be able to provide my vehicle information for my vin number:
I'm looking for the model specifically but if you have the full factory sheet that would be handy too.
Many thanks
Adam
Many thanks
Adam
- x 6963
Hi Adam
Here you are:
Here you are:
| Vehicle family | C4 PICASSO / C4 SPACETOURER (B78) |
| AS/RP N° | 14536 FV 2 0382 |
| Warranty Start Date | 10/10/2016 |
| Engine serial number | 10 JBHD 3063450 |
| OPB | 006Q |
| BER | e2*2007/46*0356*12 |
| P4A | 9807591099 |
| VEHICLE FAMILY | C4 PICASSO / C4 SPACETOURER (B78) |
| SILHOUETTE | ESTATE - LEISURE |
| TRIM LEVEL | HIGH HIGH |
| ENGINE | DV6FC FAP 88KW TURBO DIESEL |
| TRANSMISSION | AUTO GBOX 6-SPEED STT |
| PAINT TYPE | METALLIC LACQUER |
| BODY COLOUR | EPY - RUBY RED PAINT |
| INTERIOR TRIM TYPE | TRIM.FINN VELOUR "1H" |
| GEARBOX (CHARACTERISTICS) | AT6 AUTOMATIC GEARBOX |
| EMISSIONS STANDARD (ENGINE) | EURO 6.1 ENGINE EMISSION CONTROL |
| SPEED SENSOR SIGNAL | FRONT WHEEL SENSOR NON-SIGN RR SIGNED |
| CATALYTIC CONVERTER | CATALYTIC CONVERTER BELOW 50PPM |
| COOLING MOTOR | RADIATOR 28DM2 - EP18 BRAZED ALU |
| EOBD SELF-DIAGNOSIS SYSTEM | "EOBD" SELF-DIAGNOSIS |
| VEHICLE TECHNICAL DEPOLLUTION | EURO 6.1 VEHICLE TECHNICAL EMISSION CONTROL |
| FAN | 1 2-SPEED FAN 95W AERO |
| TANK FILTER | RESERVOIR FILTER INTERIOR |
| STOP AND START | WITH STOP AND START ALTERNATOR STARTER |
| FINAL DRIVE RATIO | FINAL DRIVE RATIO 15 X 58 |
| WHEEL STYLE | 17-INCH AQUILLON BLACK ALLOY WHEEL 7 J17 CH 5-50 |
| CLUTCH | WITHOUT CLUTCH |
| RIM/TYRE SIZE | 17 INCH TYRE FITMENT |
| TYRE (SIZE, TYPE) | 205/55 R17 95V REINFORCED TYRE |
| WHEEL (TYPE) | ALLOY WHEEL ASSEMBLY 1 |
| GEARBOX TYPE | AT6 3 AUTOMATIC GEARBOX |
| REAR ANTI-ROLL BAR | STIFFNESS 30000 NM/RAD |
| FRONT ANTI-ROLL BAR | FR ANTI-ROLL BAR DIAMETER 23 HOLLOW |
| SUSPENSION (ARCHITECTURE TYPE) | METAL SUSPENSION |
| STEERING (OPERATION) | LOW POWER DOUBLE PINION ELECTRIC POWER STEERING |
| Body Fittings | |
| HORNS | HORNS-HARMONY |
| AERIAL | ROOF AERIAL + GPS + DIGITAL + INTEGRATED |
| WHEEL EMBELLISHER (STYLE) | WITHOUT WHEEL CAP |
| UNDERBODY SHIELD | WITHOUT PROTECTION UNDER BODY |
| INDICATORS | SIDE MARKER LIGHTS |
| DRAUGHT EXCLUSION | FR AND RR DOOR AERODYNAMIC SEALING |
| EXT. REARVIEW MIRROR COMP. FUNCTION | ELECTRICMEMORY FOLDING EXT REAR VIEW MIRROR |
| ENGINE BAY SOUNDPROOFING | SOUNDPROOFING FOR BULKHEAD + BONNET + WHEELARCH + AC POWER TRAIN |
| WINDSCREEN WIPER | 2 SPEED INTERMITTENT+AUTOMATIC CADENCING |
| HEADLAMP WIPER | W/O HEADLAMP WIPER |
| FRONT PANEL BLANK | WITHOUT FRONT BUMPER PLUG |
| ROOF GLASS | WITH ROOF WINDOW |
| BUMPER | BODY COL FR BUMPER+BLACK CAPPING CHR BEAD/BODY COL RR BUMPER |
| LUGGAGE RACK | MOUNTING WITH ROOF BARS |
| FRONT FOGLAMP | FOG LAMPS WITH CORNERING LIGHT |
| PANORAMIC VISUAL AID | WITHOUT PANORAMIC VISUAL AID |
| SPARE WHEEL | SPACE-SAVING SPARE WHEEL |
| EXTERIOR ACCESSORIES | EXT HANDLE BLACK + CHROME RING |
| WINDOW (TYPE) | LAM ATHERM+ACOUS WINDSCREEN + TOUGH REAR SCREEN |
| HANDS FREE ACCESS AND STARTING | FRONT ACCESS + BOOT + HANDS FREE STARTING |
| ANTI-THEFT ALARM | WITH THEFT PROTECTION ALARM |
| SUPPLEMENTARY SEAT | 2 PLACES SUPPLEMENT SEPAR SEATS |
| BLIND SPOT DETECTION | WITH BLIND SPOT MONITORING |
| LUGGAGE COVER | LUGGAGE COVER + WINDSTOP |
| FRONT SEATBELT | PYROT PYROTECHNIC SEAT BELT DOUBLE WITH ALARM |
| CLIMATE (AMBIENT TEMP) | HOT OR WIDER TEMPERATE COUNTRY |
| AIR CONDITIONING | WITH HEATER MATRIX |
| GEAR SELECTOR | GEAR CONTROL AT THE STEERING WHEEL |
| CONSOLE | WITH REMOVABLE CONSOLE |
| ADDITIONAL HEATING | WITHOUT ADDITIONNAL HEATING |
| AIR EXTRACTOR | STANDARD AIR EXTRACTOR |
| LOAD SPACE LIGHTING | WITH GLOVEBOX LIGHTING |
| BOOT AND LOAD SPACE LIGHTING | BOOT + LOAD SPACE + AMV LIGHTING AUTO CONTROL |
| DASHBOARD EQUIPMENT | UPPER PART PEARLESCENT ARDOISE GREY |
| INT. TRIM AND EQUIPMENT VARIATION | CLOTH INTERIOR EQUIPMENT TRIM |
| MISC. INT. LAMPS | LIGHTING BY LEDS |
| WORK TABLE | WITH WORK TABLE |
| LOAD SPACE TRIM | FOAM BOOT MAT + SOUNDPROOFING |
| UNDERSEAT STORAGE | 1 UNDER SEAT STORAGE DRAWER |
| INSTRUMENT PANEL (CHARACTERISTICS) | DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS |
| DOOR TRIM | DECOR GLOSS VARNISH |
| ADDITIONAL BLOWER | WITH ADDITIONAL PULSE |
| PASSENGER COMPARTMENT SOUNDPROOFING | SOUNDPROOFING FOR BULKHEAD + TUNNEL TOP RANGE |
| FRONT PASSENGER SEAT HEIGHT CONTROL | FRONT ADJUSTMENT PASSENGER SPACER |
| DRIVER SEAT CONTROL | DRIVERS FRT SEAT MANUAL CNTROL |
| FRONT PASSENGER SEAT CONTROL | FRONT SEAT CONTROL MANUAL + RELAX |
| DRIVER SEAT ADJUSTMENT | DRIVER’S SEAT TILT BACK ELECTROPN LUMBAR SUPPORT |
| FRONT PASSENGER SEAT ADJUSTMENT | PASSENGER LUMBAR ADJUSTMENT |
| FRONT PASSENGER SEAT FOLDING | WITH FOLD PASS FRONT SEATING |
| FRONT SEAT ARMREST | DRIVER ANT PASSENGER FRONT ARMREST |
| STOWAGE BIN | FLAPS IN FLOOR |
| HEADLAMP BULBS | HALOGEN BULB |
| TRAFFIC INFORMATION READER | WITHOUT LATERAL TRAJECTORY MONITORING |
| DISPLAY | DGT TOUCHSCREEN+12" DFT DISPLAY |
| FOOTWELL LIGHTING | DRIVER’S FOOTWELL + DOOR TRIM PAD LIGHTING |
| ELECTRIC WINDOW (OPERATION) | DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH |
| COURTESY LAMP | CONTROLS FOR FRONT + REAR DOORS, FRONT + REAR INTERIOR LAMPS |
| HEADLAMP HEIGHT ADJUSTER | REMOTE MANUAL HEADLAMP ADJUSTMENT |
| WIFI | WITH WIFI |
| CRUISE CONTROL | PROGRAMMABLE CRUISE CONTROL AND SPEED LIMITER |
| STORAGE (OTHERS) | NET SEAT BACK STORAGE POCKET |
| CARPET COVER | CARPET MAT 1 |
| TUNER RADIO | DUAL RADIO TUNER |
| OBSTACLE DETECTION SYSTEM | FR AND RR RADAR OBSTACLE DETECTORS + RR CAMERA+AUTO PK |
| LATERAL BLINDS | SIDE BLINDS |
| FLOOR MAT | FR + RR MATS |
| LOCKING CONTROL | DEADLOCKING + AUTOMATIC LOCKING |
| STEERING WHEEL | LEATHER STEER WHEEL 4 BRANCHS |
| SEATING ASSOCIATED VARIANT | VARIANT ASSOCIATED WITH HIGH SEAT POSITION |
| REAR VIDEO SCREEN | WITHOUT REAR VIDEO SCREEN |
| CHILD OBSERVATION INTERIOR MIRROR | INTERIOR CHILD MONITORING MIRROR |
| Electrical | |
| ALTERNATOR | ALTERNATOR ISTT41 |
| BATTERY | BATTERY L3 760 VRLA2 EN AGM |
| STARTER MOTOR | STARTER MOTOR CL 5 |
| SPECIAL LIGHTING | FRONT DAY RUNNING LIGHT (DRL) |
| CEN. LOCKING REM CONTROL FREQUENCY | 433.92 MHZ SUPER HETERODYNE |
| MULTIPLEXING | MODIFIED ECONOMY ELECTRICAL ARCHITECTURE |
| LIGHTING OF LAMPS | AUTOMATIC SWITCHING ON OF LIGHTS |
| Miscellaneous | |
| CONDENSER (SPECIFICATIONS) | CONDENSER 19,3DM2 THICKNESS 12 |
| LABEL | WITHOUT LABEL |
| RADIO HEADPHONE SOCKET | TRIPLE ACCESSORIES SOCKET |
| SIDE IMPACTS | DOOR WITHOUT REINFORCEMENT |
krio1987
- x 4
Thank you Marc thats a great help, much appreciated
KennethPM
Hi how can i get what engine i have in my C3 1.4 Diesel 2012. i have my VIN & Engine no.
Kenneth
Kenneth
- x 6963
Hi Ken, just post your VIN up here. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff. Do you require a factory build sheet like I did for Adam above?
KennethPM
Hi Marc factory a build sheet would be most helpfull, Vin no: VF7**************[VIN obfuscated, can be read by forum staff]GiveMeABreak wrote: 01 Jan 2025, 12:17 Hi Ken, just post your VIN up here. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff. Do you require a factory build sheet like I did for Adam above?
thanks Kenneth
- x 6963
Here you go:
So you have a 1.4 HDi (68BHP) DV4C engine.
| Vehicle family | C3 (A51) |
| AS/RP N° | 12882 CA 2 0272 |
| Warranty Start Date | 24/03/2012 |
| Engine serial number | 10 FDBZ 0289530 |
| OPB | L00D |
| BER | e2*2007/46*0003*16 |
| P4A | 9666157299 |
| ENGINE | TURBO DIESEL DV4C |
| TRANSMISSION | BVM5 |
| BODY COLOUR | EXL - PAINT OBSIDIAN BLACK |
| INTERIOR TRIM TYPE | W&W FYBER G111 + OMNI F942 ’3M’ |
| UPHOLSTERY COLOUR | "FZ" |
| GEARBOX (CHARACTERISTICS) | BVM MA5 / O |
| DEFINITION TO FOLLOW | INITIALE RANGE |
| SPEEDOMETER DRIVE | SPEEDOMETER RATIO 21 X NO |
| FUEL SUPPLY | INJECTION PRIM |
| CATALYTIC CONVERTER | 2 FILTERING COMPONENTS IMPREGNATED WITH PLATINUM+PADIUM 50G |
| FUEL TANK | FUEL TANK WITHOUT LOCATING TAB |
| COOLING MOTOR | RADIATEUR EP:27 - 16 DM2 ALU BRASE SS MEC |
| CRANKCASE GAS CIRCUIT HEATING | W/O HEATER CASING GAS CIRCUIT |
| FAN | 1 100W AERO 2-SPEED FAN |
| FINAL DRIVE RATIO | REAR AXLE HYPOID GEARSET 16 X 63 |
| WHEEL STYLE | 15 INCH PATRICK WHEEL |
| DIFFERENTIAL (GEARBOX) | DIFFERENTIAL 77 |
| TYRE (SIZE, TYPE) | 185/65 R15 88H NON REINFORCED TYRE |
| GEARBOX TYPE | MA |
| Body Fittings | |
| AERIAL | LONG ROOF AERIAL |
| EXHAUST TAILPIPE TRIM | W/O EXHAUST OUTLET EMBELLISHER |
| SPARE WHEEL | EMERGENCY WHEEL |
| LOUDSPEAKER | ASSEMBLY 2 FR SPEAKERS + 2 RR SPEAKERS |
| RADIO RECEIVER | AUDIO CD SYSTEM RDS "RD45" MP3 |
| OBSTACLE DETECTION SYSTEM | WITHOUT OBSTACLE DETECTOR |
| Electrical | |
| Miscellaneous | |
| SPECIAL SPECIFICATION | SPECIAL SERIES 2 |
| REFRIGERANT | WITHOUT REFRIGERANT LIQUID |
