Diagnostics codes assistance- thp 1.6 156bhp
508c5
- x 4
Re: Diagnostics codes assistance- thp 1.6 156bhp
,coming to think of it , how can i really tell if its engine oil Or transmission oil..or maybe rust(!!) ?
- x 6957
Have a look at David's thread - you can see pictures of a when the gearbox cooler has failed.....
viewtopic.php?p=625376#p625376
508c5
- x 4
OMG...not there , no overheating, no gunk spilling out, dark bronze color in the coolant reservoir, gears shift normally. So, i guess we are left with either engine oil or rust (car was not maintained by me and dont know whether coolant was used or plain water
Onlinemyglaren
- x 5674
Probably simplest to drain and flush the coolant and replace with fresh and see how it looks after a couple of weeks.
508c5
- x 4
HiGiveMeABreak wrote: 06 Feb 2022, 12:27 You haven't included the fifth code. You really need ALL these as the faults can present 'knock-on' faults as a result of other faults.
These are the descriptors for the 4 you have provided:
Fault Code: P0A1A Description of Fault: Signal from the piloted alternator (BSS line): Value received incorrect. The following conditions have to be met:
- Engine management ECU in main triggering phase
- Communication with alternator valid
Possibility 1
Detection of a loss of communication on the line BSS (No synchronisation on the line) : The time of appearance of the fault code is 0,05s
Possibility 2
The communication manager BSS is in timeout: The time of appearance of the fault code is 0,05sConditions for Fault to clear: Communication with the piloted alternator in conformity : For at least 0,05 s Downgrade Modes whilst Fault is active: Symptoms: Unstable idling, Idle speed too high Suspect Areas: Electrical harness, Alternator
Fault Code: P0945 Description of Fault: Oil pressure regulation solenoid valve control : Open circuit. Detection of an open circuit on the control of the oil pump pressure regulation electrovalve.
- Battery voltage between 9 and 17,9 V
- engine running
- Power relay jammed for more than 2 secondsConditions for Fault to clear: Absence of the fault codes P0945, P0947, P0948 for 1 s Downgrade Modes whilst Fault is active: Change to "mechanical mode" on the piloted oil pump Symptoms: - Suspect Areas:
- Electrical harness
- Oil pressure regulation solenoid valve
- Oil pump
- Engine ECU
Fault Code: U0140 Description of Fault: CAN network : Communication fault with the BSI ECU. No communication with the BSI (CAN network disconnected; Short-circuit on the CAN High/CAN Low line; Loss of information on the CAN network)
- Engine running for 2,5 sConditions for Fault to clear: The fault disappears after a certain number of consecutive datastreams received without any fault Downgrade Modes whilst Fault is active: Deactivation of the air conditioning
"reverse gear" information from the BSI not taken into account
Deactivation of the vehicle cruise control and speed limiter
Information "brake uncertain" sent on the CAN network
Deactivation of the "pedal jammed" diagnostics
Deactivation of the additional heating element
Activation of the catalytic converter heating no longer dependent on the engine stopping time
Activation of downstream sensor heating diagnostics no longer dependent on the engine stopping time
Activation of upstream sensor heating diagnostics no longer dependent on the engine stopping time
Mixture adaptation and combustion mode modified
Starting impossible
Alternator always activated on starting
Temperature of the alternator no longer dependent on the engine stopping time
No use of the fuel level as a model for fuel temperature
Deactivation of diagnostics of the plausibility of the maximum/minimum petrol levelSymptoms: Unstable idling, Lack of power, Engine hesitation, Excessive fuel consumption, Activation of the vehicle cruise control impossible, Down-graded cabin heating Suspect Areas:
- Built-in systems interface
Fault Code: P0016 Description of Fault: Synchronisation : Lack of coherence between the engine speed sensor information and the inlet camshaft sensor information. Dephasing too great between the inlet camshaft and the crankshaft.
- engine running
- Inlet camshaft in the reference position
- Synchronisation done
- No error on the inlet camshaft signalConditions for Fault to clear: After several engine rev cycles without any error in the dephasing between the inlet camshaft and the crankshaft Downgrade Modes whilst Fault is active:
- Blocking of the ignition/fuel injection in the synchronisation checking phase (After engine restart)
- Prohibiting of adaptation and control of the inlet camshaft
Symptoms: Starting difficult, Emissions outside the norms Suspect Areas:
- Inlet cylinder reference sensor
- Inlet variable timing electrovalve
- Dephaser
- Setting the timing
Dephaser - which part is it?
- x 6957
Ok, so I can't keep up with your vehicles - so you have a garage or something?
What's the VIN for this one?
508c5
- x 4
I was just referring to the "dephaser" mentioned in the code description (p0016), not specifically to my car.
Reason: Removed Quote
508c5
- x 4
Can you indicate the part number for the mentioned dephaser? For the car in questionGiveMeABreak wrote: 07 Sep 2023, 22:23 Ok, so I can't keep up with your vehicles - so you have a garage or something?
Thx
- x 6957
As per my last question - which vehicle is this for - I need the VIN.... as you have multiple vehicles in your topics.
508c5
- x 4
But it isn't necessary, just wanted to be sure which part is the phrase refering to (the cam thothed wheel?)
- x 6957
The (1) bolt (Inlet camshaft dephaser (5))
The inlet camshaft dephaser (5)
The bolt (3)(Exhaust camshaft pinion (3))
The exhaust camshaft gear (4)
- x 1070
So what does a 'dephaser' do?
Champion of Where's CitroJim
Onlinemyglaren
- x 5674
Removes the phasers from the hands of the Star Trek mob.
- x 1070
I was afraid of that....
- x 1459
It moves the timing of one camshaft relative to the crankshaft. Some engines have just one on the inlet camshaft, and some engines have one on each camshaft .
