Citroen C5 2009 EGR valve
doctle
- x 223
Re: Citroen C5 2009 EGR valve
Thats a primer under the bonnet, AFAIK there should be a pump in the tank
Oh buggle
- x 6945
We really need the VIN, not all the 1.6 diesels have a pump in the tank, just a sender gauge.
Sufii
- x 3
Try to post the VIN number soon as possible, but the engine code is 9HZ
- x 6945
That will be a 1.6 HDi 110 particle emission filter with (DV6TED4) engine - and these do not have a pump in the fuel tank - just a sender.
Sufii
- x 3
Then? I still don’t know how to bleed the fuel lines.
Sufii
- x 3
I know that there is a screw on the top op the fuel filter, but so I have to pump, and then open the screw?
Or open the screw first and then pump til it’s coming clear fuel from the pipe on the fuel filter?
- x 6945
Follow the procedure here for bleeding (illustrated) - this is what you need to do if you were changing the fuel filter on this engine specifically:
https://www.frenchcarforum.co.uk/forum/ ... 97#p529497
You will need some of the tools shown.
Sufii
- x 3
Thanks for good help.
Difficult prosess, think I have to leave this one for workers.
Sufii
- x 3
Find this little plug under the EGR , the fuels lines is going in to this. Old EGR valve melted this part. Someone know what this is for?
- x 6945
If it's the 5 pin black plug then it's the EGR solenoid valve plug - controls the solenoid and throttle motor commands etc.
Sufii
- x 3
Don’t know how many pins it is, but when I run diagnostic, it’s no fault codes about that. Only something about glow plugs. Still not possible to start the car
Sufii
- x 3
This is the fuel rail pressure sensor. Weird that the diagnostic dosent show this problem. Can someone help me with the oem part number for this part?
- x 6945
The EGR won't be near the rail - the rail fuel pressure sensor is on the end of the rail here on the right hand side - item (1)
Your photo is hard to identify what you are looking at as it's too close in.
Citroen only sell the complete rail with sensor.
Sufii
- x 3
Here can you see that the sensor is right under the egr valve
- x 6945
The part for the fuel rail (with sensor) is 1570G2:
You can get the sensors on their own from aftermarket suppliers.
