Xantia clutch replacement by dropping end of engine down?
x 94
Re: Xantia clutch replacement by dropping end of engine down
Unread post by citronut »
romie wrote:oh, apart from a 'clutch-kit', is there anything else I should get prior to doing this job?
Any replacement bits or special tools?
Or is it just the clutch kit I need really?
it pays to fit new diff seals and fork shaft nylon bush's, you will also need the correct gear oil ( 75/80 BV spec ) other specs are detrimental to PSA box's
i havent read all in the link below but quick glance tell you about PSA specific oil's,
looks an interesting web site
http://www.oilspecifications.org/psa_pe ... itroen.php" onclick="window.open(this.href);return false;
Regards, malcolm.
romie
Re: Re:
Unread post by romie »
citronut wrote:
addo wrote:Yes, and if its got a drive pin holding the fork shaft to the cable lever, you may want a plan for this being difficult.
you NEED to remove the pin holding the actuating arm to the fork shaft, this allows the fork shaft to rotate and disengage the fork prongs/fingers from the thrust bearing on removing and re/fitting the box,
:) Cheers guys
ahhhh, found it. This pin thing :)
No. 5 in below image yeah?
Citroen Xantia 1.9TD 1996 estate 100% veg 323k
Ford Transit Tourneo 2.5L Di 1999 165k
Yamaha R1 1999 26k
Kawasaki ZXR750 L1 1993 66k (to LPG?)
Suzuki Bandit GSF400 1992 x 2
Mountain bike, skateboards, snowboards, surfboard, longboard and feet!
romie
lexi wrote:I think it may be an idea to replace the white nylon top hat bushes in release mech.
citronut wrote:.....and fork shaft nylon bush's...
I presume the above two comments are of the same thing?
If so items 6 and 7 in the below image? :)
ta, romie
Yamaha R1 1999 26k
romie
Re:
Is this a bit of a mission then? :/
Yamaha R1 1999 26k
romie
Oh and I presume these fork shaft nylon bush's are a dealer only available part?
Yamaha R1 1999 26k
romie
citronut wrote:...it pays to fit new diff seals...
Items 9 and 10 in below image?
Yamaha R1 1999 26k
x 1496
I think I looked on e-bay not long ago, and there were some of the bushes, but they were at least as much as the dealer price (which is not disasterous!). The pin sometimes refuses to come out - the only thing you can do then is cut the arm off and replace it, as you can't get the box off otherwise. You would be best advised to replace the inlet shaft / seal guide tube, which again is not that dear from the dealer (and used to be available from GSF I think).
Do not fit a Transmech clutch. Valeo (OE) would be the preference, but Sachs is probably OK.
romie
RichardW wrote:I think I looked on e-bay not long ago, and there were some of the bushes, but they were at least as much as the dealer price (which is not disasterous!). The pin sometimes refuses to come out - the only thing you can do then is cut the arm off and replace it, as you can't get the box off otherwise. You would be best advised to replace the inlet shaft / seal guide tube, which again is not that dear from the dealer (and used to be available from GSF I think).
ah, many thanks!
My alternator is Valeo. Cheers :)
These bushes, the dealer said he does not carry them in stock and so I have to buy the number that comes in the bags!
Clutch fork bearing top £2.18+vat MOQ of 5!
Clutch fork bearing bottom £2.83+vat MOQ of 4!
grrrr!
"replace the inlet shaft / seal guide tube", I need to figure out what these are :/
Thanks RichardW, romie :)
Yamaha R1 1999 26k
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Try AEP in Glasgow, or Neat Car Parts for the fork bushes each. You might also try Gearchange who are on Ebay.
The part you refer to most recently is the tube which the thrust bearing slides on, and carries both the front bearing for the gearbox input shaft, and an oil seal. Can be had aftermarket as well, none are dear.
x 1496
Bushes on E-bay
Input shaft guide / seal is part number:
05
2105 35
01 CLUTCH BUFFER GUIDE BUSH
- BE3
Genuine one on e-bay also Aftermarket ones there for about £10. Dealer price is £17.04 as per the e-bay ad.
x 94
dealer price and that ebay listing price are the same, as EVANS HALSHAW PEUGEOT in the ebay add are a dealer
Regards, malcolm.
romie
RichardW wrote:Bushes on E-bay
05
2105 35
- BE3
Cool, thanks for finding them and providing links! :)
Yamaha R1 1999 26k
romie
05
2105 35
- BE3
Fantastic, got these :)
Yamaha R1 1999 26k
romie
aha, after reading a few posts on here it looks like I'll need a 35mm socket n breaker bar :p
Yamaha R1 1999 26k
addo
x 95
Aye; get an impact socket, six point thin wall. And a metre long "persuader". If you have steelies with the hole in the centre you can crack the nuts with wheels on. Might need a short extension to achieve the correct orientation.
