Xantia clutch replacement by dropping end of engine down?
romie
Unread post by romie »
hey-up.
Has anyone replaced a clutch in a Xantia 1.9TD 1996 Estate by unbolting the engine mounts on the clutch end, and dropped that end down through the engine bay for access?
Is it possible/worthwhile?
The clutch has not actually gone, it's just rather juddery and has been adjusted out rather a lot. Anyway of testing to see if it actually needs replacing?
250k with original clutch! How's that? :)
ta, romie
Citroen Xantia 1.9TD 1996 estate 100% veg 323k
Ford Transit Tourneo 2.5L Di 1999 165k
Yamaha R1 1999 26k
Kawasaki ZXR750 L1 1993 66k (to LPG?)
Suzuki Bandit GSF400 1992 x 2
Mountain bike, skateboards, snowboards, surfboard, longboard and feet!
Lighty
x 35
Re: Xantia clutch replacement by dropping end of engine down
Unread post by Lighty »
Normal replacement method if you ask me, did one last week. Used to get 9hrs for one of them, so don't underestimate them, bit tricky
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Stewart(oily)
x 35
Unread post by Stewart(oily) »
That is the way, not massively complicated but loads of it :)
x 94
Unread post by citronut »
its actually the gear box mount you separate, this does allow the gear box end of the engine to till downwards,
i have just finished on on an R reg TD XANT,
you must pull the O/S drive shaft out of the intermediate bearing housing, and obviously the N/S shaft out,
i have a wonderful engine support beam that sits across the top of both inner wing edges,
and it has two adjustable support hooks, one for engine and one for the box,
http://www.ebay.co.uk/itm/Sealey-ES502- ... 0863599301" onclick="window.open(this.href);return false;
the link is the same as my one,
but i only payed about £38 quid new including carriage a few years ago now though
Regards, malcolm.
VertVega
x 13
Unread post by VertVega »
romie wrote:Has anyone replaced a clutch in a Xantia 1.9TD 1996 Estate by unbolting the engine mounts on the clutch end, and dropped that end down through the engine bay for access.
In mine clutch + flywheel was taken down, just as you described above.
Crankshaft seal was replaced and all that work had to be done ... :roll:
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
romie wrote: 250k with original clutch! How's that? :)
ta, romie
Not bad.. my hdi is on 257k all original but no judder... :wink: :-D
Theres not a lot left though... :-D
A very sad...
1994 XM 2.1 d auto
romie
fantastic, thanks for heads-up :D
Yamaha R1 1999 26k
romie
oh, apart from a 'clutch-kit', is there anything else I should get prior to doing this job?
Any replacement bits or special tools?
Or is it just the clutch kit I need really?
(Thanks malcolm, nice engine support beam. I was thinking of lowering engine using a jack from underneath?).
Yamaha R1 1999 26k
romie
ta, romie
Maybe I could wait 7k or more before doing? :D
I don't know if mine actually needs doing?
It just judders a bit when pulling away.
Anyway of testing? Or at 250K, I should just replace it anyway?
What's the longest mileage anyone has known a Xantia clutch to go for? :)
Yamaha R1 1999 26k
citroenxm
Fallen Hero
x 70
So far mine is the longest ive known! I know its done a lot or original because I only just touch the pedal and the clutch starts to disengage. With just 2 inch's of pedal movment the clutch is fully disengaged..
A very sad...
1994 XM 2.1 d auto
romie
Maybe I should wait and we can have a contest! :p
Yamaha R1 1999 26k
lexi
x 134
Unread post by lexi »
I think it may be an idea to replace the white nylon top hat bushes in release mech.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Yes, and if its got a drive pin holding the fork shaft to the cable lever, you may want a plan for this being difficult.
romie
lexi wrote:I think it may be an idea to replace the white nylon top hat bushes in release mech.
addo wrote:Yes, and if its got a drive pin holding the fork shaft to the cable lever, you may want a plan for this being difficult.
Great, I'll get on with finding out what these bits are, thanks :)
Looking at ECPs, they're recommending: Sachs Clutch KitPart No.: 641545370 List Price £257.30 Was £104.40 Now £78.00 Save 25%
There are a number of these kits on ECPs, think I better put something decent in. Sachs a good one?
Others are:
Valeo Clutch Kit Part No.: 641545050 Was £138.00 Now £103.20
Transmech Clutch Kit Part No.: 641545051Transmech Clutch Kit Was £83.94 Now £62.40
Clutch Kit Part No.: 64154505G Clutch Kit Was £190.79 Now £181.79
Transmech Clutch Kit Part No.: 641545371Transmech Clutch Kit Was £71.94 Now £49.80
Yamaha R1 1999 26k
x 94
Re:
you NEED to remove the pin holding the actuating arm to the fork shaft, this allows the fork shaft to rotate and disengage the fork prongs/fingers from the thrust bearing on removing and re/fitting the box,
Regards, malcolm.
