What worked for me was to find an empty carpark and slacken the remaining bolts off a couple of turns then drive around the carpark and get some heat into the hub by using the brake it will take a while but you will feel the wheel coming lose.
just be carefull
Locking Bolt Removal....
meexi
Re: Locking Bolt Removal....
2004 C3 XTR HDI 16V 92bhp
2004 Xsara Picasso Exclusive HDI 16V 110bhp
1989 Peugeot J5 Hymer B694 2.5td intercooled 8v 96bhp
SaabC5
See my friend use this tool yesterday to remove locking nuts off an Audi A6, did all four wheels in approx 15 mins flat! Problem is you can't buy the tool unless you are an approved garage using a company credit/debit card, its not available to the general public for obvious reasons.SaabC5 wrote:A lot of garages carry a special tool to remove locking wheel nuts these days. Its a hardened steel socket with a softer compound metal inside, its hammered onto the nut creating a once only "key" to remove the nut. Its usually about £40 to remove.
A link to the actual tool.. http://www.dynomec.co.uk/indexEnglish.html
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
addo
- Sara Watson's Stalker
- x 95
- x 8260
If the locker is the pin type Paul, you should see there is a small raised circular bit in the middle. This is enough for a reverse flute socket to get hold of it and unscrew it.
I've done these types in the past with success - ask Toby HDI... He came to see me for 'P bushes one day and forgot his locking key....
citroenxm
- Fallen Hero
- x 70
Your spot on Jim, there is a small bit in the middle..
Can you point me to one for sale, I cant seem to find any..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
addo
- x 95
Paul - this wrapped up yesterday:
http://www.ebay.co.uk/itm/250915506637" onclick="window.open(this.href);return false;
It's interesting how nobody much talks about how it works. Basically the renewable section fits inside a sleeve; the whole jobbie is smacked with an impact driver which forces a couple of prongs/blades into the periphery of the wheel nut whilst simultaneously twisting it all. The prongs are captured by the sleeve, so tightness is assured.
The Birdman
You could always just get the wheel locking code and order a new locking nut from the Dealer and remove it.
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
citroenxm
- Fallen Hero
- x 70
Thats the obvious which the owner did first.. But surprisingly the dealer was NOT interested!The Birdman wrote:You could always just get the wheel locking code and order a new locking nut from the Dealer and remove it.
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
andy5
- x 103
Re:
There's another just appeared, on buy it now, £80addo wrote:Paul - this wrapped up yesterday:
might not stay there long
addo
- x 95
