Locking Bolt Removal....
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
..... unoficially... :)
By this I mean, any ideas how to remove locking bolts when the Bolt "Key" is not present???
Ive tried the "Belt a socket over the bolt and try" tactik, but that hassnt worked..
Will I have to make something to fit in the holes... Judging by the 3 other bolts they arent excessivly tight..
Ideas???
Cheers
Paul
A very sad...
1994 XM 2.1 d auto
robert_e_smart
x 14
Re: Locking Bolt Removal....
Unread post by robert_e_smart »
You can buy a lock nut extractor kit.
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
citroenxm
Fallen Hero
x 70
... yes Robert... at 106 quid! :shock:
Paul
A very sad...
1994 XM 2.1 d auto
x 8422
Try and Irwin Reverse-flute socket Paul. I've used one successfully for just this job in the past...
Chlorate
Unread post by Chlorate »
If you have a good hand drill...
Find a bit that is the same diameter as the threads on the bolt - or slightly less - punch, pilot and drill. The heads on those lock bolts are usually quite soft.
Once the wheel is off you should be able to get hold of the rest of the bolt with a pair of mole grips.
That is of course if you don't mind ruining the bolt :D
Alex
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police :evil:
handyman
Unread post by handyman »
Hi Paul, are these the earlier bolts with the pegged socket or the later ones with the milled stub?
If its the later, an old socket hammer on usually does the trick. The hammering sometimes helps to shock the thread and loosen it up a bit. :shock:
On the earlier bolts and stubborn late types, I use a LEFT HANDED STUB drill bit to make a hole in the centre of the bolt and then use an Easi-Out. I have had them come out whilst drilling, as its anti-clockwise. They never seem to be really tight as its not possible to over-tighten security bolts without them snapping. #-o I've yet to have to drill right through to collapse the threads.
I assume these are on Xantia alloy wheels? [-o< If so, none of the so called removal sockets work as the recessed hole in the rim is too tight to get the sockets in. I've even tried turning down the sockets, with dire consequences. :hb: :domo: :taz:
If you were nearer, you could bring the car to the workshop and I'd have the wheels off in a trice! :mrgreen:
H
SaabC5
Unread post by SaabC5 »
A lot of garages carry a special tool to rmeove locking wheel nuts these days. Its a hardened steel socket with a softer compound metal inside, its hammered onto the nut creating a once only "key" to remove the nut. Its usually about £40 to remove.
citroenxm
Fallen Hero
x 70
Ooooo i omitted to say... Its on a customers 1991 h reg 205 gti...
Paul
ps. I posted here as its more popular then the pug section.. Sorry admin/mods
A very sad...
1994 XM 2.1 d auto
dnsey
x 19
Unread post by dnsey »
Never tried it, but if it's not tight would a length of hardwood with nails knocked through in the appropriate places work, perhaps?
Norlander
Unread post by Norlander »
Just got a vision of Basil Fawlty going Rambo........ :lolhit:
(sorry!) :oops:
citroenxm
Fallen Hero
x 70
dnsey wrote:Never tried it, but if it's not tight would a length of hardwood with nails knocked through in the appropriate places work, perhaps?
Hmmm that may be an idea, even better a bar of steal with bolts in them... worth a try im sure!
Paul
A very sad...
1994 XM 2.1 d auto
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Can you see a code stamped on the bolts?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
citroenxm
Fallen Hero
x 70
Hi Richard
I didnt really look close enough, I saw them tried looking for the key.. couldnt find it and though Oh <censored word> typical!!
Paul
A very sad...
1994 XM 2.1 d auto
DickieG
x 33
I have a few wheel nut keys, I'll have a look at a couple of sets I have to see whether the code is visible from the top, are they the bolts with three holes on the top?
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
citroenxm
Fallen Hero
x 70
Yes Richard, they are the Pinned ones.... The owner went to Peugeot and they werent interested!!
That be great.. Ill try and get a picture of a bolt head to see the Pin layout from the owner...
Paul
A very sad...
1994 XM 2.1 d auto
