Locking Bolt Removal....
meexi
Re: Locking Bolt Removal....
Unread post by meexi »
What worked for me was to find an empty carpark and slacken the remaining bolts off a couple of turns then drive around the carpark and get some heat into the hub by using the brake it will take a while but you will feel the wheel coming lose.
just be carefull
2004 C3 XTR HDI 16V 92bhp
2004 Xsara Picasso Exclusive HDI 16V 110bhp
1989 Peugeot J5 Hymer B694 2.5td intercooled 8v 96bhp
SaabC5
Unread post by SaabC5 »
SaabC5 wrote:A lot of garages carry a special tool to remove locking wheel nuts these days. Its a hardened steel socket with a softer compound metal inside, its hammered onto the nut creating a once only "key" to remove the nut. Its usually about £40 to remove.
See my friend use this tool yesterday to remove locking nuts off an Audi A6, did all four wheels in approx 15 mins flat! Problem is you can't buy the tool unless you are an approved garage using a company credit/debit card, its not available to the general public for obvious reasons.
A link to the actual tool.. http://www.dynomec.co.uk/indexEnglish.html
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour) :wink:
addo
Sara Watson's Stalker
x 95
Unread post by addo »
150 squid on Fleabay; not too shabby a margin on the gear.
x 8272
If the locker is the pin type Paul, you should see there is a small raised circular bit in the middle. This is enough for a reverse flute socket to get hold of it and unscrew it.
I've done these types in the past with success - ask Toby HDI... He came to see me for 'P bushes one day and forgot his locking key....
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Your spot on Jim, there is a small bit in the middle..
Can you point me to one for sale, I cant seem to find any.. :?
Paul
A very sad...
1994 XM 2.1 d auto
addo
x 95
Paul - this wrapped up yesterday:
http://www.ebay.co.uk/itm/250915506637" onclick="window.open(this.href);return false;
It's interesting how nobody much talks about how it works. Basically the renewable section fits inside a sleeve; the whole jobbie is smacked with an impact driver which forces a couple of prongs/blades into the periphery of the wheel nut whilst simultaneously twisting it all. The prongs are captured by the sleeve, so tightness is assured.
The Birdman
Unread post by The Birdman »
You could always just get the wheel locking code and order a new locking nut from the Dealer and remove it.
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
citroenxm
Fallen Hero
x 70
The Birdman wrote:You could always just get the wheel locking code and order a new locking nut from the Dealer and remove it.
Thats the obvious which the owner did first.. But surprisingly the dealer was NOT interested!
Paul
A very sad...
1994 XM 2.1 d auto
andy5
(Donor 2022)
x 103
Re:
Unread post by andy5 »
addo wrote:Paul - this wrapped up yesterday:
There's another just appeared, on buy it now, £80
might not stay there long
addo
x 95
Bit of a bargain! Someone on Autoshite will blag it.
