FAP Fluid priming?
fred1
Unread post by fred1 »
Fuel gauge on C5 appears to work by registering the actual tank contents at fill up and when the engine is turned off and restarted. In between times it calculates the level by measuing how much fuel is being used.
I found this out when I suffered a large leak from a filter connection whilst on a motorway journey.
Fuel gauge behaved as normal but I got an increasing smell of diesel.
When I pulled into a service area to investigate, the gauge was still showing 3/4 full. When I stopped and subsequntly restarted the engine, having first fixed the fault, the gauge showed empty! This was confirmed by the fuel it took to fill the tank.
John
x 1939
Unread post by Paul-R »
fred1 wrote:Fuel gauge on C5 appears to work by registering the actual tank contents at fill up and when the engine is turned off and restarted. In between times it calculates the level by measuing how much fuel is being used.
I know, it's dreadful isn't it.
It also needs at least 10 litres of fuel to be put in before it even acknowledges that anything has been added. I regularly top up jut 5 - 10 litres in order to brim the tank for accurate fuel consumption figures and roll out of the fuel station with exactly the same reading on the gauge.
Of the cars I've ever had I distrust the C5's gauge more than anything else. There should be option that the Lexia can set along the lines of "just tell me what the sender unit in the tank is reading".
cachaciero
x 9
Unread post by cachaciero »
jimleshed wrote: As mine is an early C5, I will need a Lex with the older type 30 pin connector/adaptor I guess. Probably of chinese origin. Will take a look at Fleabay.
No 16 pin std connector is what you need.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
jimleshed
Unread post by jimleshed »
We'll see then, have ordered one....
Jim Le Shed
Citroen C5 2.2 HDI Exclusive
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
Citroen GS (lots of other Cars and Bikes too!!)
cachaciero
x 9
myglaren wrote:I always run mine until I get the low fuel warning the it accepts around 62 litres.
Supposed to be a 65 Litre tank but I have managed to get 72 in on one occasion.
Probably a cold day :-)
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
x 5672
cachaciero
Just the opposite, it was a swealtering day in early September the year before last.
cachaciero
x 9
cachaciero
Interesting I wonder just how fuel pumps meter, the amount of energy you are buying is proportional to weight not volume. Volume varies with temperature and in the case of diesel that's quite a lot.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
MikeT
x 232
Lexia
Unread post by MikeT »
jimleshed wrote:We'll see then, have ordered one....
Pity I didn't see your thread earlier - I'm in Christchurch if it's not too far to travel and am offering free sessions to FCF members.
x 5672
I presume that there was just a faint whiff of diesel left in the tank that day. Fuel pumps are checked for accuracy fairly frequently I believe and this was quite a recent installation.
jimleshed
Thanks MikeT, but I've ordered it now, and waiting with bated breath for its arrival.
I'm sure when it arrives I'll have a few questions....
Jim Le Shed
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
