Hi,
Fuel gauge on C5 appears to work by registering the actual tank contents at fill up and when the engine is turned off and restarted. In between times it calculates the level by measuing how much fuel is being used.
I found this out when I suffered a large leak from a filter connection whilst on a motorway journey.
Fuel gauge behaved as normal but I got an increasing smell of diesel.
When I pulled into a service area to investigate, the gauge was still showing 3/4 full. When I stopped and subsequntly restarted the engine, having first fixed the fault, the gauge showed empty! This was confirmed by the fuel it took to fill the tank.
John
FAP Fluid priming?
- x 1939
I know, it's dreadful isn't it.fred1 wrote:Fuel gauge on C5 appears to work by registering the actual tank contents at fill up and when the engine is turned off and restarted. In between times it calculates the level by measuing how much fuel is being used.
It also needs at least 10 litres of fuel to be put in before it even acknowledges that anything has been added. I regularly top up jut 5 - 10 litres in order to brim the tank for accurate fuel consumption figures and roll out of the fuel station with exactly the same reading on the gauge.
Of the cars I've ever had I distrust the C5's gauge more than anything else. There should be option that the Lexia can set along the lines of "just tell me what the sender unit in the tank is reading".
cachaciero
- x 9
No 16 pin std connector is what you need.jimleshed wrote: As mine is an early C5, I will need a Lex with the older type 30 pin connector/adaptor I guess. Probably of chinese origin. Will take a look at Fleabay.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
jimleshed
cachaciero
- x 9
Probably a cold daymyglaren wrote:I always run mine until I get the low fuel warning the it accepts around 62 litres.
Supposed to be a 65 Litre tank but I have managed to get 72 in on one occasion.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- x 5673
Just the opposite, it was a swealtering day in early September the year before last.cachaciero wrote:Probably a cold daymyglaren wrote:I always run mine until I get the low fuel warning the it accepts around 62 litres.
cachaciero
cachaciero
- x 9
Interesting I wonder just how fuel pumps meter, the amount of energy you are buying is proportional to weight not volume. Volume varies with temperature and in the case of diesel that's quite a lot.myglaren wrote:Just the opposite, it was a swealtering day in early September the year before last.cachaciero wrote:Probably a cold daymyglaren wrote:I always run mine until I get the low fuel warning the it accepts around 62 litres.
cachaciero
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- x 5673
jimleshed
Thanks MikeT, but I've ordered it now, and waiting with bated breath for its arrival.
I'm sure when it arrives I'll have a few questions....
Jim Le Shed
Citroen C5 2.2 HDI Exclusive
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
Citroen GS (lots of other Cars and Bikes too!!)
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
