Peugeot 2008. The new chapter
Huskyxantia
x 928
Re: Peugeot 2008. The new chapter
Unread post by Huskyxantia »
Fastener / ConnectionSocket / Tool SizeTorque Setting
Top Mount to Chassis Bolts (3x)13 mm25 Nm if car has mine didnt
Central Strut Piston Shaft Nut21 mm (Hold shaft with 7 mm Allen)65 Nm
Bottom Pinch Bolts to Steering Knuckle (2x)18 mm (Bolt head & nut)90 Nm
Anti-Roll Bar (Drop Link) Nuts16 mm or 17mm(Hold stud with 5 mm Allen)40 Nm
Wheel Lug Bolts17nmm100 Nm
:-D
ozfrog
(Donor 2026)
x 84
Unread post by ozfrog »
Huskyxantia wrote: 09 Sep 2026, 18:12 So turns out I was sent a tie rod to fit an m16
Eh?
Why would anyone send you something to fit a 405 when you clearly have a 2008?
Oh, wait. Sorry. The word ‘thread’ was just on the next line, and it wasn’t immediately clear to me that they were meant to be related to each other! The brain can play tricks sometimes. 🙄
Cheers,
Andrew
Huskyxantia
x 928
ozfrog wrote: 18 Sep 2026, 22:54
Eh?
The most annoying thing was the so called new thing ebay rolled out the amazing thing that assured buyers it was the correct fit for your car , come to think of it ive not noticed it since, maybe they have messed up big time and scrapped it ,
And yes the inner thread on this new one was to big it just fell straight over the inner tie rod.
Brain playing tricks , know what you mean by that
Here's one i got wrong when i first started driving
​"Fine for parking" as "Hey, great news! Parking is completely fine here!" Till the ticket graced my wind shield....
:-D
Huskyxantia
x 928
Used the car today all good noise has gone and ive noticed the driver side feels better aswell.
:-D
Huskyxantia
x 928
300 plus miles since and everything seems as it should be .
:-D
x 8441
Huskyxantia wrote: 27 Sep 2026, 08:15 300 plus miles since and everything seems as it should be .
Excellent :-D May it continue to be so [-o<
Huskyxantia
x 928
My car parts for reference
:-D
Huskyxantia
x 928
Peugeot 2008 Brake Overhaul Complete! 🚗💨
​Just wrapped up a full brake overhaul on the Peugeot 2008, and it feels like a brand-new car on the road. If you're planning on tackling your own brake refresh, here is a rundown of how the job went, what parts went into it, and the key details to keep in mind.
​🛠️ The Work & Prep
​Thorough Rust Removal & Cleaning: Before putting anything back together, all the mounting surfaces, caliper brackets, and hubs got a deep clean. Stripping away years of accumulated brake dust and rust ensures everything sits completely flush, prevents uneven pad wear, and keeps components from binding.
​New Brake Pads: Fresh pads installed all around for a crisp, confident bite when pressing the pedal.
​⚙️ Rear Disc Specifics
​When doing the rear brakes on these models, it’s worth noting a couple of key details:
​Pre-Installed ABS Rings & Bearings: The new rear brake discs came with the ABS tone rings and wheel bearings already pre-installed, which saves a massive amount of hassle compared to pressing old bearings out and new ones in.
​New Hardware: Finished off the rear hub assembly with brand-new hub nuts and fresh dust caps to keep moisture and dirt well away from the bearings.
​📐 Torque Specifications Reference
​Doing the job right means getting the torque figures spot on for safety and peace of mind:
​Center Hub Nut: Torqued up high to specification (typically around 300 Nm for these integrated bearing setups — always double-check your exact manual variant). My variation turned out to be 270
​Wheel Bolts / Nuts: Standard tightening set to 100 Nm in a proper star pattern.
​Caliper & Guide Pin Bolts: Cleaned up and torqued carefully to manufacturer spec to ensure smooth sliding action without any risk of loosening.
​Everything is cleaned, greased where appropriate, torqued down properly, and road-tested. A deeply satisfying weekend job!
I need another one of these .. im snapping them to much
Nice and clean and greased,  both sides same as each other
New
New
New
New
In with the new
In with the new
Out with the old
Out with the old
Napa seems to be a good brand
Rear discs part number
:-D
x 8441
Great work Husky :cool:
x 2367
Unread post by MattBLancs »
T50 torx snapping - hang on, I'll try and find the "impact quality" set I bought that seem to be doing ok (i.e. not snapped any yet!)
x 2367
Not sure it's this brand, but just like this:
https://ebay.io/m/hTpYbO
Huskyxantia
x 928
Nice one Matt ive just purchased a set and the price was great they look like there tough enough too.
:-D
Huskyxantia
x 928
https://temu.to/k/e8e9gn4p34x
Was worth a punt, ive got 2 old wheel bearings to remove as a project these will be worth the purchase to experiment with cant wait till they arrive
:-D
Huskyxantia
x 928
This little set was less then twenty pounds and has paid for itself no end of times .
Highly useful piece of kit
:-D
Huskyxantia
x 928
Dangerous.... Daft.....
:-D
