Pauls HDI Xantia Exclusive.
x 8406
Re: Pauls HDI Xantia Exclusive. will be OFF the road again!
Paul, I may be really off the money here but the Lexia faults might just indicate an electrical problem on something common to all those items such as a duff/high resistance earth or a duff/intermittent/low supply. That might well account for the odd behaviour. The front loom or fusebox may be implicated.
Did all the faults successfully clear and stay away?
If you need HDi wiring diagrams and layouts let me know...
As I say, I may be wrong but it might bear a check and investigation.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Ooo yes jim they did clear and stay away. The only one to return is the lack of high pressure measurement or what ever it says.
Moment of truth for starting. Just stepping out the door to goto farm...
A very sad...
1994 XM 2.1 d auto
x 8406
Fingers crossed Paul and also [-o<
citroenxm
Fallen Hero
x 70
Well, swapped the Tank Fuel pump, and the double relay... and.. other then not stalling, and still taking a few more turns then normal starting, still THE SAME.
Cutting out......
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
Doh!!!!
What live pressure readings are you getting Paul?
Have you checked any and all electrical points that could have been disturbed when doing the clutch?
Have you thought about swapping injectors from the hdi90?
Sorry it's dragging on :(
citroenxm
Fallen Hero
x 70
Its NOT injectors, look at the video above! Theres virtually NO flow correction, as in leak off....
The live parameter video shows it all aobve!
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
Sorry can't see it on my phone :(
citroenxm
Fallen Hero
x 70
On page 8 will.. previous page..
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
I mean I can't view it on my phone :( it's in shock wave format not supported on iPhones :cry:
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Paul, any more luck?
looks like I have similar issues.. car has been getting worse at cold starting for last few weeks, now it wont start at all, 5C outside.. hoping to get lexia on it for the (my) first time ever.. may need a little help with that information.,
just to clarify, you can change the fuel pump on an Hdi without upsetting cambelt tension?
John
citroenxm
Fallen Hero
x 70
Yes you can BUT be carefull to make sure the pump pully sits nicely and safely.
Theres no bolt holes to secure the pully, it needs to rest.. then when you re fit the pump it will tighten up again.
HDi pumps ARE NOT TIMED on these 2.o 8v engines..
As for my car. She still doesnt start instantly, and still cuts out under hard load, however, she does start a little better.
Out of interest JOhn, have you checked your heater plugs??
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
Before she cuts out does she feel like she is a little low on power?
Gutted that it's still being a bugger for you Paul ;(
citroenxm
Fallen Hero
x 70
NOPE she still has full 110 horses. Theres NO signal, NO sign, it just happens.. engine stops dead!
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
Im gunna stick to the earthing issue then or wire that is not making 100% contact.
x 8406
KP wrote:Im gunna stick to the earthing issue then or wire that is not making 100% contact.
That's not a bad area to look into I must agree Will...
