Pauls HDI Xantia Exclusive.
KP
x 27
Re: Pauls HDI Xantia Exclusive. will be OFF the road again!
Unread post by KP »
Sorry can't see it on my phone :(
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
On page 8 will.. previous page..
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
I mean I can't view it on my phone :( it's in shock wave format not supported on iPhones :cry:
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Paul, any more luck?
looks like I have similar issues.. car has been getting worse at cold starting for last few weeks, now it wont start at all, 5C outside.. hoping to get lexia on it for the (my) first time ever.. may need a little help with that information.,
just to clarify, you can change the fuel pump on an Hdi without upsetting cambelt tension?
John
citroenxm
Fallen Hero
x 70
Yes you can BUT be carefull to make sure the pump pully sits nicely and safely.
Theres no bolt holes to secure the pully, it needs to rest.. then when you re fit the pump it will tighten up again.
HDi pumps ARE NOT TIMED on these 2.o 8v engines..
As for my car. She still doesnt start instantly, and still cuts out under hard load, however, she does start a little better.
Out of interest JOhn, have you checked your heater plugs??
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
Before she cuts out does she feel like she is a little low on power?
Gutted that it's still being a bugger for you Paul ;(
citroenxm
Fallen Hero
x 70
NOPE she still has full 110 horses. Theres NO signal, NO sign, it just happens.. engine stops dead!
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
Im gunna stick to the earthing issue then or wire that is not making 100% contact.
x 8391
KP wrote:Im gunna stick to the earthing issue then or wire that is not making 100% contact.
That's not a bad area to look into I must agree Will...
jgra1
(Donor 2021)
x 36
hi Paul, will add to my cold start problem post shortly
will need some guidance on my first ever lexia session, albeit brief one .
J
citroenxm
Fallen Hero
x 70
I shall fully update when confidant tonight after we go out again later. But it appears to be ok now.
I swapped the injectors over from the hdi 90 and also the fuel filter element. 40 mile drive home no issues.
Idle still has a varying pressure reading though. Piccs and further details added later if she behaves rest of the day..
A very sad...
1994 XM 2.1 d auto
Trainman
(Donor 2018)
x 43
Unread post by Trainman »
Fingers crossed.............
Steve
http://c6owners.org/index.php
x 8391
Trainman wrote:Fingers crossed.............
And toes [-o<
And any thing else that's crossable...
citroenxm
Fallen Hero
x 70
Yup, been out again tonight, NO problems... The starting is heater plugs, when cold takes a bit longer then normal, but NOT 10 turns!!
She starts fine when Hot, one turn to two... so, as per the headache thread, HERE thanks goto RichardW for his injector explaination..
Soooo... anyone want to buy a GOOD HDi Xantia?? :-D :-D :-D
A very sad...
1994 XM 2.1 d auto
x 8391
That's really excellent Paul :-D
