Pauls HDI Xantia Exclusive.
KP
- x 27
Re: Pauls HDI Xantia Exclusive. will be OFF the road again!
Sorry can't see it on my phone
citroenxm
- Fallen Hero
- x 70
On page 8 will.. previous page..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
KP
- x 27
I mean I can't view it on my phone
it's in shock wave format not supported on iPhones
jgra1
- (Donor 2021)
- x 36
Paul, any more luck?
looks like I have similar issues.. car has been getting worse at cold starting for last few weeks, now it wont start at all, 5C outside.. hoping to get lexia on it for the (my) first time ever.. may need a little help with that information.,
just to clarify, you can change the fuel pump on an Hdi without upsetting cambelt tension?
John
John
citroenxm
- Fallen Hero
- x 70
Yes you can BUT be carefull to make sure the pump pully sits nicely and safely.
Theres no bolt holes to secure the pully, it needs to rest.. then when you re fit the pump it will tighten up again.
HDi pumps ARE NOT TIMED on these 2.o 8v engines..
As for my car. She still doesnt start instantly, and still cuts out under hard load, however, she does start a little better.
Out of interest JOhn, have you checked your heater plugs??
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
KP
- x 27
Before she cuts out does she feel like she is a little low on power?
Gutted that it's still being a bugger for you Paul ;(
citroenxm
- Fallen Hero
- x 70
NOPE she still has full 110 horses. Theres NO signal, NO sign, it just happens.. engine stops dead!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
KP
- x 27
Im gunna stick to the earthing issue then or wire that is not making 100% contact.
- x 8431
That's not a bad area to look into I must agree Will...KP wrote:Im gunna stick to the earthing issue then or wire that is not making 100% contact.
jgra1
- (Donor 2021)
- x 36
hi Paul, will add to my cold start problem post shortly
will need some guidance on my first ever lexia session, albeit brief one .
J
J
citroenxm
- Fallen Hero
- x 70
I shall fully update when confidant tonight after we go out again later. But it appears to be ok now.
I swapped the injectors over from the hdi 90 and also the fuel filter element. 40 mile drive home no issues.
Idle still has a varying pressure reading though. Piccs and further details added later if she behaves rest of the day..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Trainman
- (Donor 2018)
- x 43
Fingers crossed.............
Steve
http://c6owners.org/index.php
- x 8431
And toesTrainman wrote:Fingers crossed.............
And any thing else that's crossable...
citroenxm
- Fallen Hero
- x 70
Yup, been out again tonight, NO problems... The starting is heater plugs, when cold takes a bit longer then normal, but NOT 10 turns!!
She starts fine when Hot, one turn to two... so, as per the headache thread, HERE thanks goto RichardW for his injector explaination..
Soooo... anyone want to buy a GOOD HDi Xantia??
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8431
That's really excellent Paul
