Change language RT3
This is the RT3 unit and was made by Magneti Marelli
The RT3 was available in a few different hardware versions, the later ones supporting MP3 playback. These units had an optical connection to the Display Screen.
x 6960
Re: Change language RT3
Check your Private Messages.
peugeot1007Vidich
Unread post by peugeot1007Vidich »
Hello to all
I am an new owner Peugeot 1007, from 2005, petrol 1,6L.
I have an RT3-vanbus I also need the configuration CD to change language to english. Please help a fellow peugeot owner.
Bonjour à tous
Je suis nouveau propriétaire Peugeot 1007, de 2005, essence 1,6L. J'ai un vanbus RT3.
J'ai également besoin du CD de configuration pour changer la langue en anglais. S'il vous plaît, aidez un autre propriétaire de Peugeot.
x 6960
iyotov
Unread post by iyotov »
I also need a config CD for an '06 Peugeot 807, recently acquired from Switzerland. The media is now in German, if that matters, and I believe that it's the RT3 with navigation and telematics.
Thanks in advance.
x 6960
You'll ned to post the VIN up as there are 2 systems and the software is not interchangeable.
iyotov
Sure VF3**************[VIN obfuscated, can be read by forum staff]
x 6960
Ok, so check your private messages.
Ray328
Unread post by Ray328 »
Hello,
Just bought C2 VTS from 2005
VIN VF7**************[VIN obfuscated, can be read by forum staff]......
soft version: 5.52.A-2
Have original CD, but not working, maybe because its a 5.5D version
Thank you
x 6960
There are VAN and CAN systems which are not interchangeable. You must use the correct software for the correct version or you risk bricking your unit.
If you don't know which system you have, please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Ray328
Hello Marc,
Its a VAN. Which is the latest firmware?
I found 5.52 and its ok. Is this one the latest?
Thank you
x 6960
Yes 5.52 is the latest for VAN Bus Systems. Just select language from main RT3 Menu, and insert CD when asked for, follow instructions and system will restart and you should have the preferred language. Eject CD.
Ray328
Thank you Marc. My GPS is not working, no satelites found. Do you maybe know where is the GPS module in the car? Is it on the windshield?
x 6960
You will have to determine where the fault is.
1) If you have updates the software first go for a drive of over 10 minutes. This is to allow the GPS to lock onto the satellites and this cannot be done when the vehicle is stationary.
2) If there are still no visible satellites, you should next buy a cheap GPS antenna with suitable fakra connector from ebay or somewhere and plug this into the back of the RT3 and leave the receiver on the dash fastened down with some tape. Then repeat the 10 minutes drive and see if the system then picks up any satellites. If it does - you know the issue is with the antenna.
3) If this still produces no satellites, then the fault is likely to be internal with the GPS tuner. When mine went, it would mean the unit being sent off to Clarion for repair, but I was already in the process of selling my C5 when this happened to me, so never got it fixed as they wanted about £400 for a repair!
The GPS tuner is internal to the RT3. The GPS Aerial is routed to the roof antenna along with the GSM and other aerials.
tecnomar
Unread post by tecnomar »
Hello i want to change my peugeot 607 2009 language to spanish.
x 6960
@tecnomar: Check your Private Messages
