1.9/2.1 td injectors - swappable?
Johnno
(Donor 2022)
Unread post by Johnno »
I'm fairly sure that the sensor injector on my 2.1 is faulty and intend to do a swap with a mate's 2.1 to check. I borrowed the special injector socket from CJ Diesels. The chap there also gave me a s/hand 1.9td sensor injector and said that it should be ok in my engine. If so, I was welcome to make an offer. GSF do not list injectors for the 2.1 Xantia and the XM parts list doesn't include the sensor.
Can the 1.9 & 2.1 items be interchanged??
Thanks,
ActivaV6uk
Unread post by ActivaV6uk »
They can, the items are exactly the same, so long as its a needle lift sensor it should be compatible with the Lucas Epic ecu too.
Andy
macaroni
Unread post by macaroni »
Johnno
(Donor 2022)
Thanks, guys. I'll do the changeover tonight. I'll also check out the ebay site when I get home as my work web access has a big, fat 'Access Denied' on ebay. Can't imagine why...
macaroni
Did you have any luck with the injectors? By co-incidence I found some 2.1td injectors in my Garage that I forgot I had. They were replaced in an attempt to solve a problem on my car, but new ones didn't make any difference, so I can safely say these are in good condition.
If you need any, give me a shout on [email protected] and and we can discuss terms, otherwise they will go on ebay.
Twiss
Unread post by Twiss »
Just a thought well more of hope really, I have a 1.9TD so can I put 2.1 injectors instead of 1.9 ? and would it make a differnce.
if so, At least if this is possiable and I can't get 1.9 injectors, I can get 2.1 instead.
Thanks Twiss
Johnno
(Donor 2022)
Hi, Twiss
For what it's worth, the 1.9 injector seems to work fine. I am assuming that with the electronic pumps then the pump only delivers the quantity of fuel required according to the feedback received. I don't claim any great understanding of the black art of diesel fueling, but I would imagine that, for most applications, you are unlikely to experience any great improvement/disadvantage with using a 2.1 injector in a 1.9. As ever, I am prepared to learn differently...
ActivaV6uk
There identical parts, the 1.9 injectors in a 2.1 is not a downgrade as they are the same specification the diference is the pumps presure and injection time thats all.
Andy
