405 rear brake pressure regulating valve
vinny180
Unread post by vinny180 »
Can anyone tell me are these valves prone to needing changing and is it difficult. haynes is a bit vague. Also how can I tell which type mine has fitted. 93 405 estate 1.9td
ralph
Unread post by ralph »
If it isn't bust, don't fix it. They sometimes sieze, and can be coaxed back into life with some WD-40 on the hinge and some gentle persuasion with mole grips.
But it's the kind of thing you'd only become aware of when an MOT tester points it out.
bikeboyz
Unread post by bikeboyz »
Its an old Peugeot design, even my 504 has one, just keep the underside clean, well lubed and it shouldnt be any bother.
Chris3005
Unread post by Chris3005 »
My 1993 405 Estate failed it's MoT on this, one year ago. There had been a tendency for the back brakes to lock up, which I'd failed to find the cause of. Diagnosis was complicated by the suspension mountings having delaminated - not easy to spot with the weight on the wheels, even on a ramp.
vinny180
Thanks for your help. spring on mechanism was broken. The valve was fine. Back brakes now functioning correctly[:)]<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Chris3005</i>
