Recent questions have highlighted the need to prevent damp getting to alarm pcb under passenger side carpet.
I have an intermittent alarm fault that occurs in wet weather - so I thought I'll lift the carpet and check the pcb. Here's the question (and I know it sounds basic) Where approx is the pcb in the footwell and what is the best way to lift the carpet to get at it. I just thought it would be a matter of a couple of pulls but it seems as if I have to dismantle the centre consul or the door trim!!!
Xantia Alarm pcb
Dave Burns
sparkyjack
Thanks for that Dave
If it is that far back it might not be the problem, but I will check in the morning.
My other thought was that water was penetrating through the plastic scuttle where it joins the base of the windscreen. I'm not sure whether there are any electrics near that would affect the alarm - anyone had any similar problems?
- x 1044
Fox
