xantia alarm
james306
xantia alarm
My alarm always goes off 3 times after I lock the car and then settles.What is the remedy?
Robin
James, unless someone comes in with a specific issue, your car is just about old enough to start getting problems with the sensors in the doors. There is a self 'disarming' capability with the alarm to stop nuisance triggering which is why it stops after three.
The door units are Citroen only sadly but they are reasonable and bought in pairs.
Just to test them, disarm them with the switch on the dashboard and then set the alarm. If it does not trigger then the sensors are shot. Hope this helps, Robin
np
Mine does the same,more so when it rains.I press the switch on the dash to dissable the interior sensors,untill the alarm light lights up(about 2 secs)then set the alarm & deadlocks as normal.It doesn`t go off then.A Citroen dealer told me this was because of water getting into the front passenger foot well.Under the carpet is a load of wires & connectors.I spray these with WD40 when the alarm plays up,more so after rainy spells,that cures it again.This may be the problem.
mbunting
james306
Robin
James, it is worth it even if only to avoid any problems with the insurers. They assume the alarm will be fully operational and could get a bit sensitive if you have 'knowingly' left it faulty.
I have just had a fault on my second car and have been given thirty days to rectify it or the theft part of my insurance is void!
Regards, R.
Regards, R.
Panjandrum
Robin
James, if you take care it is possible to ease the door interior back from the corner near the mirror to expose the connections. The door interiors or cards are held in place by clips so use a flat tool like a 1 inch wide scraper to ease the clips away from the door. The panel with the sensors in is also just clipped in place and can be eased away. The new sensors will show you how the connections are made. Colour coded for right and left. Good luck. R.
Panjandrum
