Front wheel bearing
caeclyd
Front wheel bearing
Unread post by caeclyd »
Citroen Xantia 1.9d 210,000mls
Dear All,
I have just replaced the handbrake cables,front discs and pads.
I went for a test run.....brakes are great but there is a slight rumble from the front nearside wheel bearing.I have jacked the car up and there is a very small amount of movement when you push and pull the wheel.
I have had a look at the Haynes manual and there is a hint of specialist equipment i.e bearing pullers of which I do not have.
Would it be easier just to obtain the front hub unit from a scrappy or replace the bearing?
Thanks,
Rory
reblack68
Unread post by reblack68 »
I changed a wheel bearing on my Renault 21 recently, which is pretty much the same job. I certainly won't be attempting it without a press again. Removing the old item involved MAJOR hammering and careful use of a grinder. Fitting the new one involved using a vice and the old bearing shell to press the new one in. I had to pull the vice handle round while my friend belted the vice with a very big hammer. Not something I will repeat.
With that in mind I say your options are a garage (shouldn't take much more than an hour with the proper tools, you can even supply the bearing if you want) or a secondhand hub. I'd prefer the peace of mind of a new bearing but it depends on your supply of time versus money and your intentions for the car.
Guru Meditation
Unread post by Guru Meditation »
Bugger.....my offside front wheel bearing is shot I think-I have the new bearing, was thinking about having a go myself this weekend....and guess what.....yep...all I have to help me is a bench with a vice and some bearing pullers.....****. Maybe I should take it to a garage and supply the bearing.
x 1479
I had a front wheel bearing changed on my Xantia for £80 at the local 'back street' garage. Given the hassle of this job, it's not even worth breaking the tools out! If you want a half way house get the hub off, and take that to your local garage and get them to put the new bearing in with their press.
caeclyd
Thanks Guys.
The garage option was my next step. I changed the front offside wheel bearing on my 306 98 td a couple of years ago. It took most of the afternoon and a trip to a workshop.
The bearing on the 306 were on then shaft. From the haynes manual they are in the hub.
Thanks again.
Rory
