RT6 / RNEG2 firmware 2.86B (9691894880) for USB?installation
- x 1955
Re: RT6 / RNEG2 firmware 2.86B (9691894880) for USB?installation
I think that you can use MiraScripts to change the startup screen logo. viewtopic.php?p=866819#p866819
MarioC88
Hi all,
my Peugeot 3008 from 2014 is showing me now a blank screen in the head unit. The CD player makes the noise of ejecting a CD on regular basis. No control are working. It seems like that this is a common issue with the RT6. Unfortunately, I can not tell which current version is installed.
I've already replaced the microSD card and tried to flash the version 2.86 via USB to the head unit. At least it showing the Peugeot logo, but it aborts the installation after a few minutes with 'CRC Error'. Would it be possible to get the software file please? Any older version will do. Just to get everything going again. Thanks a lot in advance
- x 1955
Query posted twice, see response here viewtopic.php?p=878186#p878186
elnurx1626
Hi, im having the same trouble, could you send me please firmware for USB-stick?gergrecrem wrote: 07 Oct 2026, 01:17 Hi Paul-R,
I am having the same issue as ankl212 but mine is a 2016 C3.
Is there any chance that you would be able to send me a copy of the RT6/RNEG2 2.86B firmware for me to put on a USB please?
Thanks in advance
Thamks in advance!
- x 1955
Have you read this fork of the query to see if it solves your problem?
elnurx1626
Hi Paul! Im reading your messages about RT6 on the different posts and trying to repair mine as well.Paul-R wrote: 07 Oct 2026, 09:28 Check your PM for links. As I've repeatedly said, I cannot guarantee that it's sub-ver B
Usual disclaimers. Use at own risk, etc.
Could you be so kind to help me please, i am out of ideas.
Quick summary of what i did:
1. Citroen DS3 has been bought few month ago with "broken" head unit. Black screen, reboots itself, like by everyone else when internal SD card fails.
2. I bought new 16gb class 10 and 8gb sd card and tried with both. Both of them unpacked and fit directly in the car, i think if it is new i dont have to extra format it because its blank?
3. Tried different files with firmware from internet - 2.86 doesnt react at all. By older versions it starts with - "Flasher loading" and in few seconds - "Disk check..." and then "Error during flasher loading..." and reboot.
4. As a last try i bought original CD from ebay for 30euro and copied all files to flash drive and tried again. It is 2.86 version so again no reaction. Just black screen and reboots.
5. 2 different flash drives for 8gb were used. Formatted to FAT32 and Sys file from windows deleted.
Do you have any suggestions? Can i have please ur version of firmware to try?.
I wonder why 2.86 does not react at all, but older versions say "Error during flasher loading..."
Can be problem in internal sd card?
- x 1955
You don't know what version firmware was originally fitted but the lack of interaction with 2.86 suggests it's quite early. I suggest you try upgrading in stages. If a later version is fitted the upgrade will be ignored but if not, well it should be the start of the process.
I would suggest > 2.37 > 2.77 > 2.80
2.37 are files for copying on to a USB drive. The other's are ISOs from which you will have to extract the files.
I would stop at 2.80 if that installs and everything works. I have 2.85 as a next step if you want it though. Check your PM in 5 minutes.
elnurx1626
Thank you! I will try tomorrow again!
elnurx1626
HI again!Paul-R wrote: 27 Nov 2026, 19:21 You don't know what version firmware was originally fitted but the lack of interaction with 2.86 suggests it's quite early. I suggest you try upgrading in stages. If a later version is fitted the upgrade will be ignored but if not, well it should be the start of the process.
I did try suggested method, unfortunately did not succed.
1. Old sd card which i dismounted is corrupted - whole file explorer is lagging when connecting it to my PC. Also tried to copy an image - failed. Means i have to forget about old sd.
2. New sd is formatted to FAT32. Class 10 16gb sd card. Windows files deleted, all clear.
3. When trying via USB stick: "CRC Media check for a several minutes", then "Flasher check...; Disk check...;" and finnaly "Error during flasher loading...".
Question is - how to install firmware to a new sd card? I mean it seems that instructions that i found is about "update", but not installing new.
Do you have any expirience with that?
- x 1955
What USB stick are you using? What size is it? Is it a recognised make? Have you ever successfully used a USB stick to play music files?elnurx1626 wrote: Today, 10:493. When trying via USB stick: "CRC Media check for a several minutes", then "Flasher check...; Disk check...;" and finnaly "Error during flasher loading...".
There is no difference that I am aware of between updating and installing new. Having said that I have not updated firmware personally.elnurx1626 wrote: Today, 10:49 Question is - how to install firmware to a new sd card? I mean it seems that instructions that i found is about "update", but not installing new.
elnurx1626
Thank you for your reply!
1. I have never played music from USB because head unit wasnt working since i bought this car.
2. I have 2 USB sticks:
-first is Philips USB 2.0 8GB stick
-second is Intenso USB 2.0 8GB stick
