Zelandeth
x 1613
Unread post by Zelandeth »
Actually starting to think about tail lights a bit this evening.
The rear end really needs to be tidied up a bit.
Aside from painting the reversing sensors (which scared the bejeezus out of me the first time I backed into a parking space as I had totally failed to notice they were there) the right colour...
One of the reversing lights lenses has clearly exited the chat at some point and had a vaguely similarly shaped lens siliconed over it. The other isn't far behind.
It's interesting to see that this looks to be the reversing light from a Mark 1 Fiesta. The fog light switch is also an 80s Ford parts bin item, so you do have to wonder if the necessary conversion work was actually done by a dealer when the car arrived here in 1989.
The reversing lights on there however are really ugly. The use of the factory reversing lights for the indicators really is sub optimal as well as they're far, far too close to the centre of the car in my opinion. They'd have been far better putting amber lamps in the lights on the bumper and using those as the indicators, leaving the reversing lights undisturbed.
Have two ideas currently in my head. First is largely returning things to stock. Easy enough to tack on a set of LED indicators purely for the MOT. Though that still leaves me with two ugly great holes in the bumper. Plus the faff of needing to swap stuff around periodically, and technically not being legal.
Second is finding something to integrate into the bumper using those existing cutouts to better provide the necessary UK spec bits in terms of indicators and fog lights.
My current front runner is a pair of these.
Far closer to fully flush surface mounting, fairly discreet and would see the indicators moved back to a far more sensible position near to the side of the car. Would also allow me to return the reversing lights to normal, along with the high level brake light which is currently being the fog light. Added advantage of readily and cheaply available.
Fact is there are already two holes in the bumper anyway - so I figure I may as well at least make them do something useful and look a bit tidier rather than looking like trailer bits stuck onto the rear bumper.
Open to other suggestions as to donor lamp clusters which would work for this application, but these are currently the front runners I think. Mark 1 Escort would have been another possible option, but they're a bit big and I don't need the reflector portion - they're also about 10 times the price of the Discovery I ones I'm looking at.
Current fleet:
07 Volvo V70 SE D5, 89 Ford Thunderbird, 85 Sinclair C5, 84 Trabant 601S, 73 AC Model 70, 62 Rover 110.
x 8458
Was great to see you yesterday Zel :D I love that car even more now I've seen it :cool:
Your current rear indicators look very red!
My drain problem took until dark to resolve - all caused by a massive build-up of baby-wipes :evil:
