I've had my interior blowers on cool all year, but now it's got cold weather I've only just started putting the heaters on and I've noticed that it's blowing only slightly warm air on the centre and driver side - but nice and hot on the passenger side (when set to high).
I have the dual climate control on front, so you can set different temperature on passenger/driver side.
RIGHT HAND DRIVE VEHICLE
But with them both set to high, it's only hot on the passenger side - with the middle and driver side blowing slightly warm/cool (depending on how fast the fans are on).
When I put the windscreen de-mist button on, it just seems to blow cool air.
I've checked the hoses in the ending bay and they're both hot so doesn't seem to be a blockage - but still possible?
I've been hearing a 'pop' kind of sound from bottom/behind centre console (maybe passenger side) when the flaps are meant to be opened/closed - but I don't know if that's the normal sound of them closing.
Without taking the trims off, I suspect that it's maybe the gears that are the issue - there are no errors on Diagbox.
I've seen the part number for;
passenger side gears - 9821297680 (14 on diagram)
Heater matrix - 643619 (10 on diagram)
Actuators - 1609705180 (5 on diagram)
Radiator - 9821299980/1609730580 (not shown in diagram)
But as my issue is the driver side, is this all controlled by that same gear on the passenger side, or is there another gear somewhere else? (Driver side).
The parts menu just appear list 1 on passenger side, 1 heater matrix and 3 actuators (1 on passenger side, and 2 on driver side)
VIN number - VF7**************[VIN obfuscated, can be read by forum staff]
C4 Picasso 2017 Hot Air Only on Passenger Side (left side)
danlat1415
- x 24
- x 8171
Re: C4 Picasso 2017 Hot Air Only on Passenger Side (left side)
I have no knowledge or experience of this. However my interpretation of your description, and the diagram you posted, would suggest that the trouble lies with the driver's side actuators which I presume are the number 5s in the diagram? It occurs to me that you may have a fault in the loom feeding those actuators as I wouldn't have thought both would fail at the same time, but I may well be wrong!! However if that line of thinking helps while you wait for a reply from an experienced member then great! Good luck
OnlineRichardW
- x 1500
Matrix blockage on these is common, and progressively affects the heat from the RH side first (as the flow is in the LH end). If it will cycle between 'warm' and cold if you adjust the temperature once the engine is warmed up, then I would suspect the matrix - but you say there are fault codes?
danlat1415
- x 24
Thanks - sorry my post was meant to say NO errors on Diagbox.RichardW wrote: Today, 12:22 Matrix blockage on these is common, and progressively affects the heat from the RH side first (as the flow is in the LH end). If it will cycle between 'warm' and cold if you adjust the temperature once the engine is warmed up, then I would suspect the matrix - but you say there are fault codes?
I've updated the post.
I need to strip the sides of the centre console to physically have a look to see if the cogs/arm works correctly
But I'm leaning more towards the radiator - which, like you say, can get clogged starting on the right hand side, meaning on the left side of it heats up, slowly reducing how much as it gets more and more clogged.
Am I able to change the radiator out without draining the whole system?
I've seen a video on youtube of it being replaced, and the guy said he didn't drain the coolant first, and it only lost a couple of hundred mils of coolant (catch in a small tub in footwell).
