C4 Picasso 2017 Hot Air Only on Passenger Side (left side)
danlat1415
x 24
Unread post by danlat1415 »
I've had my interior blowers on cool all year, but now it's got cold weather I've only just started putting the heaters on and I've noticed that it's blowing only slightly warm air on the centre and driver side - but nice and hot on the passenger side (when set to high).
I have the dual climate control on front, so you can set different temperature on passenger/driver side.
RIGHT HAND DRIVE VEHICLE
But with them both set to high, it's only hot on the passenger side - with the middle and driver side blowing slightly warm/cool (depending on how fast the fans are on).
When I put the windscreen de-mist button on, it just seems to blow cool air.
I've checked the hoses in the ending bay and they're both hot so doesn't seem to be a blockage - but still possible?
I've been hearing a 'pop' kind of sound from bottom/behind centre console (maybe passenger side) when the flaps are meant to be opened/closed - but I don't know if that's the normal sound of them closing.
Without taking the trims off, I suspect that it's maybe the gears that are the issue - there are errors on Diagbox.
I've seen the part number for;
passenger side gears - 9821297680 (14 on diagram)
Heater matrix - 643619 (10 on diagram)
Actuators - 1609705180 (5 on diagram)
But as my issue is the driver side, is this all controlled by that same gear on the passenger side, or is there another gear somewhere else? (Driver side).
The parts menu just appear list 1 on passenger side, 1 heater matrix and 3 actuators (1 on passenger side, and 2 on driver side)
VIN number - VF7**************[VIN obfuscated, can be read by forum staff]
