PSA NAC RCC Updates
This is the Connected NAV system.
Main Features: It is a fully integrated Telematics System featuring CarPlay, Android Auto, Real Time Services, Voice Commands, High-Res Display, 3D Navigation, Bluetooth Hands Free & USB. 2 versions of the system are available NAC (Navigation Audio Connectée) and RCC (Radio Couleur Connectée) or Connected Colour Radio, which does not have the Integrated Navigation or Live Services.
gcdec
Re: PSA NAC RCC Updates - Map version 21.0.0-r0 failed to install
Unread post by gcdec »
rui_saraiva wrote: 25 Oct 2026, 18:36
gcdec wrote: 23 Oct 2026, 00:20
gcdec wrote: 15 Oct 2026, 15:49 Hello, I had no problem a few months ago updating my maps to 20.0.0-r0. My car is wave 4, and has the most up to date firmware installed 44-07-33-32_NAC-r0. I saw there was a new map update 21.0.0-r0. I downloaded it. I formatted my 32gb sandisk usb stick to Fat32, and using 7zip sent files straight to usb stick. I am using windows 11. Went in my car and started it and turned off start stop, engine running, but every time I insert usb stick in car and press install on the screen a message comes up straight away saying map eur failed. Cant understand why as I have done exactly the same as I did with the map update 20.0.0-r0. If someone could help me get this problem sorted I would be so so grateful. @rui_saraiva
Can anyone confirm they have successfully installed map update 21.0.0-r0 :help2:
Is there anyone on here that can help me - the Sandisk 32gb usb stick was brand new and only used once to install map update version 20. But no matter what I do I cant get map update 21 installed. [-o< [-o<
You should first see a warning about no media files in the USB flash drive. That is expected (in fact, there aren't any audio or video files in the update) and you should just ignore that message. That also means the USB flash drive was correctly FAT32-formatted and the car could read its contents. A few seconds later you should see a message asking if you want to update the maps.
Any error after this message is usually related to:
- Update prepared in a macOS system that automatically writes extra system files to the USB flash drive. The update fails when computing the checksum of folders with those extra files (Not your case);
- The extraction utility doesn't support PaxHeaders (old versions of 7-Zip, for instance) and/or automatically convert text files (WinZip does that "smart CR/LF conversion" in its default settings);
- The USB flash drive itself might have bad flash memory. Also, many cheap drives are sold with an expected size, when, in fact, they only have a fraction of that space. File corruption occurs;
@rui_saraiva Ok purchased a brand new Kingston 32gb usb stick. Extracted folder swl and xml file. Car running inserted usb stick and update failed, see screenshots. The firmware has never been touched by me. I installed map update 20 with no problem, just don't understand why it's failing as I am doing exactly the same for map update 21 as I did with map update 20. Windows 11 and latest 7zip. Start stop off, car running, not in eco mode.
gcdec
@rui_saraiva I have tried everything I can to get version 21 installed, but soon as I click install it comes up map eur failed. New Kingston usb stick 32gb, Windows 11, latest version of 7zip, only swl folder and update.xml on usb, start stop off on car, not in eco mode, drove around for 15 minutes and engine still running before inserting usb into car port. So so weird, map up date version 20 installed for me on first attempt. Even checked today in nav settings to make sure version 20 is installed and it is. Totally baffled and really could do with some help and some brains please please. :help2: :help2: :help2:
Mogresha15
Unread post by Mogresha15 »
Hello everyone,
@rui_saraiva
Your site saw that my car (c4 cactus 2019) is wave 3 with a * mentioned that it's upgraded to wave 4
My car's current system version is 31.09.46.62_NAC-r0
Citroën app shows recommended version 42.03.33.42_NAC-r0 (that's not compatible after trying & as i understand that it's expired.
Shall i download the same version but wave 4 from your site?
Thank you
Solarriors
x 7
Unread post by Solarriors »
Is it possible to force install a NAC WAVE 4 onto a C4 Grand Spacetourer 2022 or did AI hallucinate ?
gcdec
@rui_saraiva So today I tried again. Using my Sandisk 32gb and Kingston 32gb usb stick. I formatted both drives correctly using Rufus. I extracted from .tar file straight to usb twice, one after the other. Both usb drives have only SWL folder and .xml file on them.
Went out in my car, start stop off and car not in eco mode, went for a good drive and tried both usb sticks, both get to install, press install and both times comes up on screen saying map eur failed, after that I turned on wifi and connected it via my iphone and tried again but still with the same result.
Version 20, installed on first attempt, version 21 been trying everything for weeks and now at a brick wall. Latest firmware on car as well. 😢
gcdec
@rui_saraiva Has Map 21.0.0-r0 (CG) been tested successfully with NAC Wave 4 firmware 44.07.33.32 ?, and is there any known compatibility problem causing the immediate failure before country selection?
Can you please confirm whether the CG release needs anything different from the previous CI release.
Many thanks
