Huskyxantia
x 928
Unread post by Huskyxantia »
Very interesting regards the 206 . I'm just wondering if mine didn't like all that 40° heat back in the summer , then it was an air flow or air to hot being drawn in then giving false triggers .? It seems fine now .. strange isn't it.
:-D
x 2367
Unread post by MattBLancs »
Very odd, I can't wrap my head around why PSA "hid" the regen process. It's key to the engine keeping in a running condition, but a simple "regen in progress" light wasn't considered. Very odd.
Anyway, red 308 fault code reading is order of the day: come to a conclusion on new DPF or not is my intention for this after.
x 2367
Fault reading, start position
x 2367
Clicking into Engine ECU, the three "not defined" fault then thankfully are a bit more informative!
All are Particulate Filter related:
P2463 00 detected overloaded
P246C 00 detected clogged
P24A4 00 detected blocked
Sounds like three varieties of the same thing! :)
x 2367
Keep in mind, this particulate filter was sopping wet, so I'm not surprised it logged as blocked. I'm hoping a week worth of motorway trips into the office has dried it out thoroughly now.
Fault descriptions added in a bit
x 2367
BSI fault reading has three
B160681 battery charge status unit configuration fault
B182584 oil level information fault level too low
U1f00 fault event not stored in the faults log
Oil level was a little low following the oil change then topped up. Level check today= 3/4 full.
Faults erased but "battery charge status" and "fault event not stored" both come back:
Post clearing
Post clearing
Huskyxantia
x 928
Took the old 206cc a good week of running after a back wash clean for it to get fully dry , once everything was re set you know tell the diagnostic it was new and the fluid refilled too all was good , my 308cc still doing good not a hiccup yet ..... watch this space lol
:-D
Huskyxantia
x 928
Eco mode will.cause that battery issue, false positive id say
:-D
x 2367
Huskyxantia wrote: 01 Nov 2026, 14:52 Took the old 206cc a good week of running after a back wash clean for it to get fully dry , once everything was re set you know tell the diagnostic it was new and the fluid refilled too all was good , my 308cc still doing good not a hiccup yet ..... watch this space lol
Fingers crosses to stay that way for you husky!
Totted up: it's about 200 miles of motorway it's done this week, so hopefully well dried out
x 2367
For completeness here's the other faults.
Touch screen:
Touch screen
Touch screen
Battery charge unit
Battery charge
Battery charge
x 2367
Super helpful faults! Multiplexed control panel
x 2367
Instrument panel
Instrument panel
Instrument panel
This one came straight back again once cleared.
Huskyxantia
x 928
Matt why don't you try an Autel maxicom , much more "easy"
:-D
x 2367
Huskyxantia wrote: 01 Nov 2026, 15:04 Matt why don't you try an Autel maxicom , much more "easy"
Still feel I've lots to learn my way around Diagbox, so sticking with that for the moment. My "ToughBook" with Diagbox also works with the USB Borescope (which otherwise would be scrap / obsolete! Absolutely will not run on Windows 10 or later, but it's ok on ToughBook's Windows 7)
In fact I've just realised I missed the opportunity to do "Before and After" DPF Borescope images to compare, D'oh!
Red 308 has been for a quick test run and didn't give "Engine Fault repair needed". Off to the office tomorrow, so hopefully stays happy on that run.
Gosh, feels VERY different back at full power after a week of limp mode (max rpm 2100, very very much reduced output even at that rev "limit")
Huskyxantia
x 928
As I recall using my scope during a cluster of risk warnings , the camera revealed it was a clean canister ,honeycomb block was clear too. Good to hear the power is back .
:-D
