Our other camper, the coach built Jennings Roadranger, has other problems.I was tracing a small gas leak which turned out to be from a valve in the wardrobe (now fixed) when I noticed a little dribble of water running down in the corner. After a poke and a prod it became clear that the timber frame was a lilt rotten. I'd done the other side a couplele of years ago so sort of knew what to expect - but it was a little worse than before
Shelves out and cladding stripped off, it didn't need much persuasion.
The little dangling junction box is for the connections and relays for the LED rear lights I fitted.
Most of the frame had turned into a black soggy mess that collapsed as the cladding was removed, luckily it seems to be confined to the corner section. Much scraping and digging out what was essential compost later the area was a little cleaner and tidier ready for some new wood. I went to the local Wickes and bought the relevant section in tanalised stock, which will hopefully last for a while, but rain stopped play as storm Austen was doing it's best to find the leaks that caused the original damage.
More to follow when it's dry enough to get out the Tigerseal.
