Commer Camper Shenanigans
John Pankhurst
(Donor 2026)
x 45
Unread post by John Pankhurst »
My '71 Commer Auto-Sleeper has never had a 240v hook-up, we've always relied on posting an extension lead through the side of the roof which was not ideal. We got a bit fed up of trailing leads along the work top so I decided an up-grade was needed. I made the mistake of buying a cheap £15 consumer unit off eBay and set about installing it to feed the fridge and a pair of twin sockets. I went all fancy and used sockets with built in USB connections and pattress boxes for a nice neat and flush installation and much to my surprise everything worked :)
Next I decided to test the safety trip while under load. The usual breakfast electrical appliances were plugged in (toaster and kettle) and the RCD trip button pressed - there was a distinct POP and a smell of singed insulation as the breaker minced itself :shock: That's was a little sub optimal so I decided to fit a half decent RCD and also replaced a couple of the dodgy MCB's while I was at it, the other one was only to the fridge with minimal load but at least the original enclosure seems OK :roll: Tests with the new components proved successful so now we're all ready for next year, except for the brakes :?
The lucky consumer unit shares it's cupboard space with the original Elsan 'Thunder Bucket' chemical toilet :-D
x 8151
Re: Commer Camper Shenanigans
A couple more pictures of the camper would go down well John? :)
John Pankhurst
(Donor 2026)
x 45
Our other camper, the coach built Jennings Roadranger, has other problems.I was tracing a small gas leak which turned out to be from a valve in the wardrobe (now fixed) when I noticed a little dribble of water running down in the corner. After a poke and a prod it became clear that the timber frame was a lilt rotten. I'd done the other side a couplele of years ago so sort of knew what to expect - but it was a little worse than before :(
Shelves out and cladding stripped off, it didn't need much persuasion.
The little dangling junction box is for the connections and relays for the LED rear lights I fitted.
Most of the frame had turned into a black soggy mess that collapsed as the cladding was removed, luckily it seems to be confined to the corner section. Much scraping and digging out what was essential compost later the area was a little cleaner and tidier ready for some new wood. I went to the local Wickes and bought the relevant section in tanalised stock, which will hopefully last for a while, but rain stopped play as storm Austen was doing it's best to find the leaks that caused the original damage.
More to follow when it's dry enough to get out the Tigerseal.
John Pankhurst
(Donor 2026)
x 45
mickthemaverick wrote: 23 Oct 2026, 15:31 A couple more pictures of the camper would go down well John? :)
You wish will be granted :)
Harvey the Auto-Sleeper
And Bonnie the Jennings Roadranger
x 8151
A lovely pair there John, I will be looking for something similar when my MX3 finally finds a new home!! :)
John Pankhurst
(Donor 2026)
x 45
They're lovely vans but do demand your time quite a lot, but they're worth it 8-)
PaulC5
x 703
Unread post by PaulC5 »
Looks good.
For the last 10 years new consumer units in houses have to be made from metal and I vaguely remember our 2011 caravan (when we had it) was installed to the same electrical standards (BS7671) but then was plastic. A search suggests plastic ones can be used in camper vans but I would make sure the cable connections are tight every now and again whether plastic or metal.
Another search says campervans also have to satisfy BS7671 which looks to now be on version 18. They seem to add stuff every few years so probably costs electricians a lot keeping up to date. If you can get hold of a copy you can check your installation against it unless you have already done this.
John Pankhurst
(Donor 2026)
x 45
An electrician friend is going to check it over before we venture into the wild so, hopefully, the extension lead through the roof can be confined to the storage cupboard.
x 8427
Enjoyed reading that John and good to see Commers being well loved :D
John Pankhurst
(Donor 2026)
x 45
Thanks Jim. There's still a few of us Commer fans around flying the flag :)
PaulC5
x 703
John Pankhurst wrote: 23 Oct 2026, 22:35 An electrician friend is going to check it over before we venture into the wild so, hopefully, the extension lead through the roof can be confined to the storage cupboard.
See if you can get him to provide an installation certificate saying it complies with the regs as it will help if you ever need to sell. https://electrical.theiet.org/bs-7671-1 ... del-forms/
John Pankhurst
(Donor 2026)
x 45
Work continues on Bonnies rotten frame replacement.
All the bad wood was cut out and new sections grafted in
Closed cell foam sheet for insulation, more spars were fitted after this picture
Lined with thin ply
And a coat of stain. Terrible match for the original but the cupboard will be full of stuff soon enough to hide my attempts,
Just the shelves and hanging rail to re fit then job done.
Tr7v8
x 5
Unread post by Tr7v8 »
Shame you're not closer, I run a company Ohm 8 doing various wiring including Camper wiring. The rules have changed big time especially for electric hook ups and a lot of stuff I see even from "specialists" is junk.
Incomer should be protected by 30MA and also double pole, as should be all the rest of the MCBs. Polarity warning is also compulsory.
Electrical Hook Up (EHU) is max 25M and must be 2.5mm2
Inverter earth wiring should be TT on just the inverter but TN-S-C when on EHU.
2021 Peugeot Expert L2H1 2.0 Hdi
2019 Abarth 595C
2018 MGS5 Trophy
2018 Mitsubishi Outlander PHEV SOLD
2005 Porsche Cayenne S SOLD
2000 Jeep GC SOLD
2010 Mazda MX5 Mk3.5 SOLD
2000 Porsche Boxster S SOLD
John Pankhurst
(Donor 2026)
x 45
This is the MCB I fitted and all wiring is 2.5mm2, it seems to fit the bill.
The little box in the pictures in my previous post has nothing to do with mains power it houses relays for the extra rear lights I fitted for increased visibility ( in case you were wondering :) )
