RT6 / RNEG2 firmware 2.86B (9691894880) for USB?installation
- x 1942
Re: RT6 / RNEG2 firmware 2.86B (9691894880) for USB?installation
Check your PM for links.
Use at own risk.
Use at own risk.
peug3008
Hello Paul,
can you send me the firmware for my Peugeot 3008 Allure 2015?
- x 1942
Check your PM. Link to 2.80. Use at own risk, etc.
correcaminos
Hi, I have a Peugeot 3008 and I’m looking to update the navigation firmware. Could you please advise if you can help with the update or if you recommend a service?
- x 1942
What system is fitted to your 3008? Is it an RT6/Rneg+ unit? What firmware version is currently fitted?
Why do you want to update? Are you having problems?
miltonvo
- New User
Hi everyone,
I have a 2013 Peugeot 308 Feline, and I'd like to update it to 2.86B via USB.
Could someone please send me the firmware files by PM?
Thanks in advance!
Thanks in advance!
- x 1942
peug3008
Thanks for your reply.
Do you think I can install latest firmware 2.86B ?
In that cas can you send it to me?
Pier Paolo Ronzino
- x 1942
You probably could but I have to ask why you want to install 2.86? Are you having some kind of problem you want to fix?
Incidentally, as I have repeatedly said, I cannot guarantee that 2.86 is sub-ver B.
peug3008
Actually I have the 2.80 ver, isn't it an update?Paul-R wrote: 26 Oct 2026, 12:08 You probably could but I have to ask why you want to install 2.86? Are you having some kind of problem you want to fix?
peug3008
the goal is to install the updated mapspeug3008 wrote: 26 Oct 2026, 13:24Actually I have the 2.80 ver, isn't it an update?Paul-R wrote: 26 Oct 2026, 12:08 You probably could but I have to ask why you want to install 2.86? Are you having some kind of problem you want to fix?
- x 1942
So, am I correct in thinking that you think that you have to update the firmware in order to update the maps? If you are on 2.80 I believe that is sufficient. Have you actually tried to update the maps? Do you have a source for maps?
peug3008
NoPaul-R wrote: 27 Oct 2026, 06:48 So, am I correct in thinking that you think that you have to update the firmware in order to update the maps? If you are on 2.80 I believe that is sufficient. Have you actually tried to update the maps?
Not yetDo you have a source for maps?
- x 1942
Check your PM in five minutes
ateuszek
Hello everyone. Could you please share the software? I bought a car with someone faces showing during initialization and I want to remove it
