Tales from beyond the grave AKA Dan & Emma's Black Xantia, pug 206HDi, Daniel's 206 Verve 1.4i, GTi180 plus XUD9TE 206!!
- x 8406
Re: Tales from beyond the grave AKA Dan & Emma's Black Xantia, pug 206HDi, Daniel's 206 Verve 1.4i, GTi180 plus XUD9TE 2
I'm watching with interest Dan...
ekjdm14
- x 262
Don't hold your breath too much on the mini front Jim, that's a definite "back burner" project if I even give it any more time (I'd like to at least see what went wrong, but Emma's not keen on wasting time when we could free up space and cash just scrapping it, which is fair but I want to give it my best shot).
Black hopefully will be done this week, as long as I'm allowed out of Ryan's shed (helping with wiring on his latest project, 4 stroke Honda clone engine in a Puch Maxi!)
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
- x 8406
Oh gosh, a Puch Maxi - that brings back a lot of teenage memories Dan
ekjdm14
- x 262
Well the Puch is nearly completed now, just need a spring chain tensioner roller as the sprocket is in a different spot & requires the chain to be run a little on the loose side to prevent it binding under full compression (it's got rear suspension as it's a Mini-Maxi, also has a little fairing too)
Hopefully got a photo of it in progress to attach here, but should have one when it's back on the road too. Also, Ryan's a lucky sod and has been gifted a 1979 MZ TS125 by a neighbour. Not any TS125 either, the fella is an MZ old hand & this bike was fully restored 10 years ago with alloy rims/all stainless spokes & hardware etc. It has sat under a cover outdoors since, but looks like it'll clean up really nicely. Only a little jealous of that, I had a TS250 years ago and forgot how nice they really are. Edit- Puch pretty much finished bar some tidying up & relocating the footpegs/shifter higher up possibly. The pit bike ones bolt to the bottom of the engine case & while they're fairly comfy position wise I did note Ryan's feet are quite close to the ground round corners. Will see how he gets on, but the bike's a little ripper now based on the quick test blast I had, much torquier than the old 2t engine.
- x 8406
Wow! That's a very special Puch Maxi Dan
A Maxi Honda Monkey Bike
Love it
I once had an MZ TS125 just like that one - except it had a blue tank... A pal of mine had a very nasty accident on it... Let's just say he left an imprint of his bollocks in the vertical part of the tank where it meets the seat... Hospitalised him...
And he did go on to have more children a few years later so no permanent damage
ekjdm14
- x 262
Ouch! I had a similar shunt on an XJ900 some years ago, car pulled out of a junction. "Fortunately" the impact was slightly offset and my knee shared some of the force hence my voice remains within an octave of where it started, still left a dent in the tank though! (Bike was a loss, front wheel/fork and frame all bent)
ekjdm14
- x 262
Progress!
Have finally found the time to sort out Black's rack gaiters. In the end I decided it would be less painful to just drop the subframe, remove the rack and give it a good cleaning on the bench as well as the new rubbers. Not a horrible job by any stretch & well worth it for how nicely the rack has come up (I even removed the plastic bag from the ram & washed it in hot water and washing liquid, whole rack looks about 100 times better now & the subframe bolts have some copper grease for any future work too. Fixed a couple of other small issues (o/s rear bumper mount had pulled through, sorted with a new nut, bolt & washer, replaced the epoxied Y pieces with some plastic Y's and PVC pipe and made the brake pedal a little further from the carpet.)
Accumulator seems fine but if I can find my spare one may replace that, and have 5 litres of LHM on its way to give everything a good flush through and bleed. Which reminds me of another reason I'm glad I dropped the rack out. The "LHM" that spewed from the pipes when I disconnected them was a muddy-brownish green and even appeared to have moisture in suspension... Not good & unsure how water could end up in there, but thankfully most of it escaped through the open pipes while the rack was off & I know to flush it all through now!
Hopefully she's finally ready for MoT after that...
- x 8406
Excellent work Dan
Yep, it's definitely the best to drop the subframe when dealing with Xantia racks - found that out the hard way!!!
Yep, that's how knackered LHM ends up... Some fresh will definitely help....
