C4 VTS converting to RT4 and LCD screen
This unit is the RD4 or RD45 system, made by Continental.
Usually standard equipment unless another system is specified as an option. There are Single & Dual Tuner versions. RD45 features over the RD4: The RD45 has USB connectivity & integrated Bluetooth module supporting Phone & Audio Streaming.
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
I have the opportunity to buy genuine RT4 + LCD. See photo
Since I do not have the VIN of the donner C4 I wonder what else is needed but the LCD , RT4 and the associated harnesses. Looking at Citroen Doc Backup It seems there are two options
One without amplifier
and one with amplifier item 25 in the following picture. Is the MULTIMEDIA SOFTWARE CD ( item 60 in the picture ) is essential ?
Is there anyway to know what is needed in order to grant that the RT4 and LCD will function on my C4
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 6945
Re: C4 VTS converting to RT4 and LCD screen
You will need the correct electrical harnesses, GPS aerials, GSM Aerials, Microphone (forget the one in the roof - that is integrated) and you will need it configuring to your vehicle's VIN and all the additional features that you have.
The CD is just the System operating firmware.
lancia58
(Donor 2022)
x 8
Hi
If the Cell phone is paired with the RT4 why a GSM aerials are needed ? BTW which is better the genuine RT4 and LCD or an Android system ( including all ) out of Aliexpress ? Why a CD with System operating system is delivered ?
x 6945
The Cell phone is not paired with the RT4!
There is no Bluetooth on these. The RT4 uses a SIM card that is inserted in the front of the head unit - opposite side to the red SOS button. This uses a GSM aerial connection to provide phone connectivity, emergency calling etc.
You are just showing parts diagrams - these are spare part numbers - it is not what is delivered with the system, that is for the dealers to order the correct firmware CD if needed or other replacement parts - you mustn't read this as a retail consumer - it is dealer information.
What you buy is really down to what you want. Be prepared that you may lose some functionality if you use an aftermarket head unit and you may lose the ability to activate / deactivate some car features.
deniz arda
Unread post by deniz arda »
Hello, I have rt3 navidrive system but previous owner lost the sim card tray. Can anyone send of it photos so I can look something to fit it. Thanks!
